Go to Post The fact the FIRST knows no boundaries, either geographic or cultural, is certainly one of our strongest assets as we move toward a changed culture. - Rich Kressly [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-02-2016, 20:19
GiGiZeroGravity's Avatar
GiGiZeroGravity GiGiZeroGravity is offline
Grace
AKA: Grace
FRC #3055 (Furious George)
Team Role: Communications
Rookie Year: 2015
GiGiZeroGravity is an unknown quantity at this point
Bumper length
So my team's robot has a side that is two segments, and neither of these segments is 8 inches in length. Do we need eight inches of continuous bumper on each segment? I've been reviewing the game manual, and looking around online, but everyone seems to have a different answer. Thanks.
-Grace, Team 3055
Unread 10-02-2016, 20:20
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Bumper length
Yes. 8 inches on each corner.
Unread 10-02-2016, 21:08
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Bumper length
wrap a piece of string around your robot...This is your frame perimeter. Where the string changes angles is considered an corner. From every corner you need to have 8 inches to the center of the side. If a side of the frame perimeter is shorter then 8 inches then it has to all be covered.
Unread 10-02-2016, 22:06
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Bumper length
Originally Posted by Fauge7 View Post
wrap a piece of stringWhere the string changes angles is considered an corner. From every corner you need to have 8 inches to the center of the side. If a side of the frame perimeter is shorter then 8 inches then it has to all be covered.
To add clarity "wrap a piece of string around your robot in the bumper zone around your robot...This is your frame perimeter. "
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 10-02-2016, 22:35
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
Re: Bumper length
Confusion comes from what is meant by a "side". A side is the length from one corner of your robot along the string in a straight line to the next corner. From each of these corners, there needs to be an 8 in. bumper measured from the corner of your frame.
"Side" does NOT mean the left side or the right side of that opening you have in the middle to heard the boulder.
If the "side" (the distance along that string from one corner to the next) is less than 8 in. then the entire side needs a bumper. This might happen with a robot that has short diagonal sides, or many small sides.
Look at the bumper diagram in Team Update 5 (the picture of Perimeter C) and note that the bumper less than 8 in. long on the lower right corner is "Not OK". Can't get any clearer than this.
Bottom line, you need an 8 in. bumper on each end of the front of your robot, measured from the corner of the frame perimeter.
I know that isn't what you wanted to hear, but better learn it now rather than at your first event!
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 11-02-2016, 00:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Bumper length
Actually, if a side of the frame perimeter is 16 inches or shorter then it has to be all covered.
