Go to Post Yellow bananas are the new red herrings. - artdutra04 [more]
Unread 11-02-2016, 08:23
edong4273's Avatar
edong4273 edong4273 is offline
Team 2375's Very Own Dong
AKA: Edmund "Dong" Dong
FRC #2375 (Dragon Robotics)
Rookie Year: 2015
edong4273 is on a distinguished road
Re: Error when deploying to RoboRio
Originally Posted by Greg McKaskle View Post
I'd recommend typing the name into a browser and looking at the memory usage on the web page. You can also see this on the diagnostics page. If you have puTTY or a similar tool, you can see what applications are using memory and even kill the processes.
Can you give more input on what customization or packages were installed on the roboRIO?
Greg McKaskle
The RoboRIO just has a RoboRIO image (I can check and get back to you with specifics) and some previous robot code that we deployed a couple days ago on a different computer. The RoboRIO shouldn't contain anything else.
After a while last night, I did just reimage the RoboRIO and that seems to have solved the issue, or at least, allows me to deploy the robot code. Is it necessary to reimage the RoboRIO for every update of the robot code?
Thank you for the reply.
Unread 20-02-2016, 08:48
RadhikaTheFish's Avatar
RadhikaTheFish RadhikaTheFish is offline
FRC #3815
RadhikaTheFish is an unknown quantity at this point
We called customer support and they found out what was wrong with it. Apparently, our host name was just roboRIO-3815.local instead of roboRIO-3815-FRC.local
Unread 20-02-2016, 10:24
edong4273's Avatar
Rookie Year: 2015
Hmm.. Interesting. I'll make sure to look at target names the next time I run into this problem. Thanks!
