Re: VersaPlanetary Integrated Encoder - Where should it go?
Hi, I think it would be best for it to go right before the output shaft, but it is just a preference thing.
It's a question of what maximum RPM the encoder can handle and what resolution your application requires. If you look in their spec sheet, you'll see that depending on the mode it will work up to 15k RPM (quad) or up to 6600 RPM (PWM). Keep in mind the 775 runs at 13050 RPM as you plan what mode to use and where to place the encoder.
Also, with a 196:1 reduction, please be sure to take a look at the VP load ratings to make sure you don't have a failure. Let me know if you have any questions reading through that. |
Just checked, that reduction is supported in the load ratings. I would usually put the encoder just before the output shaft to make sure the slop in the reduction gears won't play into the reading. However, I'm fairly sure that the effect would be minimal.
As another reference point:
The configuration on our turret is [BAG -> 10:1 -> 10:1 -> 4:1 -> VP Encoder -> 18:42 chain]. This is technically out of spec by a smidge but after careful consideration of the full system setup I believe it will work fine. The turret uses the really nice, sturdy Igus slew ring that prevents 'racking'. It doesn't require much torque to turn and at full motor power should only be about 4% of the maximum load rating for any of the failure conditions listed in the VP load rating guide (2.1 N-m at the hex output shaft + 100% safety margin). We went for higher precision in control since it only has a 75-90 degree FOV. In reality I don't believe the turret will ever receive full motor power - probably more like 75% while it resets to center. The thing seriously takes some oomph to turn by hand for manual alignment... Conversely, the configuration on our tilt is [BAG -> 10:1 -> 10:1 -> Encoder -> 3:1] since the load for the tilt is a bit higher of a load, at about 50% of the load rating of the failure conditions at the worst point (including 100% safety margin). It may see full power when angling backwards, so we'll remain strictly within the BAG->VP "Green" zones in the guide. Last edited by JesseK : 11-02-2016 at 13:12. |
Can't wait to see what everyone's building! ![]() Last edited by Jean Tenca : 11-02-2016 at 17:44. Reason: Two years ago*, not last year |
