Go to Post Finally, they're getting rid of the spotlights. I'm sick of seeing ridiculous inside jokes up there. - Karthik [more]
Unread 11-02-2016, 14:48
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Re: Smaller Pnuematics Storage Tank
Speaking of smaller air tanks, does anyone know where we could purchase a plastic air tank in the 300-400 ml range? (a link would be great!)
Thanks,
Mike
Unread 11-02-2016, 15:12
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Coast Pneumatics has a large number of polypropylene tanks available.
Clippard also has a selection of metal air tanks.
Unread 12-02-2016, 00:57
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
You probably wouldn't want to do this for competition, but if you're trying to figure out /verify how much tank you need, you can use a (probably large) pneumatic cylinder as an air tank. If you use the top (return) side, you can use nearly the full stroke x bore of the cylinder without moving anything. You can even tweak the volume by mechanically locking the output shaft in a given location. In fact, clippard's metal tanks are just cylinders with two "bottom" ends and no piston or rod; we have several of these and used one in 2014.
