Go to Post I tried to make them look at disgruntled as possible. - Katie_UPS [more]
Unread 11-02-2016, 08:50
kbrowncny's Avatar
kbrowncny kbrowncny is offline
Mechanical Engineering Mentor
AKA: Kevin Brown
FRC #2168 (Aluminium Falcons)
kbrowncny is an unknown quantity at this point
VexPro Bearings
Our team was planning to use VexPro hex or thunder hex bearings to support a hex shaft in a low load, high RPM application (14k RPM) . Has anyone come across any specs or ratings for hex or thunder hex bearings that they offer?
I know that I can get 1/2" bearings rated to up to 15k or 30k but turning the shaft to a round does not support our application.
In addition, what is the risk to using the VexPro bearings at that RPM?
Thanks!
Unread 11-02-2016, 08:52
Chris is me's Avatar
AKA: Pinecone
Re: VexPro Bearings
There are no specs publicly available, but teams have used the hex bearings in small wheel shooters in 2013 which spun at similar speeds.
I would suggest ThunderHex so that you don't have any minor issues with runout / concentricity, which aren't always noticeable in a normal hex bearing application but might be at high speed.
Unread 11-02-2016, 09:04
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: VexPro Bearings
Honestly the fact that vexpro doesn't have specs online really bugs me.
In the industry we have to consider all of these aspects and bearing selection is a major part of the design.
I don't know what speed vexpro hex bearings are rated for so I can't say exactly if they will work or not. However since they decided to withhold the specs I would assume that the bearing won't work.
I am going to let you in on a bit of info that 5817 learned this season. We changed out the hex bearings on the shooter with bearings from McMaster (who give specs on their bearings) with an appropriate rpm rating, our shooter spun around 1000 rpm faster with just a bearing swap.
I don't know why vexpro doesn't give us this info, I am assuming it is either 1: they don't accurately know, or 2: posting the data will harm their sales.
Let's say that the bearings have a low speed rating this could affect uses in a lot of frc applications besides shooters perhaps even some gearboxes. Vexpro also knows that students might not look into specs and thus never bring up any concern.
Good enough is the enemy of anything great!
team 1671
Unread 11-02-2016, 09:36
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: VexPro Bearings
1. It doesn't look like McMaster sells 1/2" hex bore bearings, or anything close to thunder hex size, so it sounds like you might be comparing apples to pineapples or something.
2. Have you tried asking anyone at Vex for ratings, if they're that important? I suspect the main reason the specs aren't listed is because they're in excess of nearly every FRC application.
Unread 11-02-2016, 11:05
FRC #5817 (Uni-Rex)
Re: VexPro Bearings
The McMaster Carr bearings are round bearings not half inch hex, if you lathe down the shafts you can use the round bearings. So I am not comparing apples to pineapples or something.
No I haven't reached out to vex however I still believe they should put the bearing specs on their website. And I don't believe that the bearings specs are in excess for every single frc application. I believe that their max rpm is a lot lower than everyone "assumes". I will reach out to vex about their bearing specs. But 1000 rpm difference with only a bearing swap is very significant in my eyes.
team 1671
Unread 11-02-2016, 11:21
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: VexPro Bearings
Did you miss the part where the OP said turning his shaft to round won't work for his application?. That basically means McMaster bearings won't work and he's "stuck" using commercially available hex bearings.
For what it's worth, I've never seen a problem with any of the hex bearings we've used - either custom applications or as provided in some commonly used gearboxes.
If you can contact vex and get a spec for them, you'll know for sure if it'll hold up for your application. If it doesn't, you could try something my team did last night... For one application, we have a hex shaft that we needed to put a specialty bearing (specifically a one way bearing... Those things are so cool!) right in the middle, and a hex bearing just wouldn't work. So instead we got a 3/4 ID version of the bearing, a 3/4 shaft, and bored a 1/2" hex hole in the middle. That lets us put the bearing on the 3/4 shaft, and the 3/4 shaft on the hex shaft wherever we want it, while preserving the hex on either side of the bearing for other applications.
2016: Lake Superior WFFA
Unread 11-02-2016, 12:24
REVving up for a new season
FRC #2848 (All-sparks)
Re: VexPro Bearings
Here is an old trick.... get a bearing that fits a 5/8 shaft, get a bushing that is 1/2 ID and 5/8 OD. Broach the bushing, and put it inside of the bearing. Now you have a simple hex bearing.
The one major issue with this is that I have not found a 5/8 shaft bearing with a 1.125 OD, but if that doesn't matter to you this is a good stand in solution, that many teams used to used before hex bearings were common.
On a side note, I also have been meaning to ask what the specs of the hex bearings are, both in RPM, load, and rated life. We have some that during prototyping (spinning at only moderate speeds) seemed to get really loose quickly, I assumed it was either an old bearing or we were beyond the spec. We changed the design, but it would be good to know for the future.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 11-02-2016, 12:25
Re: VexPro Bearings
Sorry, were you using half inch round Vex bearings and then switched to half-inch round McMaster bearings? If so, then I'll agree that the McMaster bearings were an improvement over the Vex.
If you're talking about switching from half-inch HEX bearings to half-inch ROUND bearings, then that's a whole different ballgame. Vex notes in a few places that hex shaft in hex bearings can have some tolerance issues, and I would expect them to have some minor issues running at higher speeds. So apples to pineapples.
Unread 11-02-2016, 13:33
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
Re: VexPro Bearings
We used Vex 1/2" hex bearings for a prototype shooter that ran with 775 pro motors at full speed with no issues.
Unread 11-02-2016, 13:38
TylerS's Avatar
TylerS TylerS is offline
AKA: Tyler Stark
FRC #1747 (Harrison Boiler Robotics)
TylerS will become famous soon enough
Re: VexPro Bearings
Early on in the design process I tried looking up the specs for both Vex Pro and Andymark's 0.5" hex and round bearings to no avail. Still we are using them anyways in our shooter simply because there's not a good alternative.
It would be interesting to get a spec sheet and some data from practical testing through typical FRC uses (shooters, drive trains, high load applications, etc) so teams can make better informed design decisions.
Purdue University 2019 - Aerospace Engineering
2016 - Team 1747 - Design & Build Mentor
2015 - Team 303 - Coach/Build Captain
2014 - Team 303 - Build Captain
2013 - Team 303 - Driver
2012 - Team 303 - Programming Leader
Unread 11-02-2016, 15:33
FRC #5817 (Uni-Rex)
Re: VexPro Bearings
I read the op I was just posting what we were able to do.
Vex emailed me back with no info, but they said they would be contacting soon in this thread.
I am just so surprised at these reactions, all I was saying is that bearing specs should be posted and how going from 1/2 hex to the McMaster high speed round bearing made a difference.
team 1671
Unread 11-02-2016, 15:46
Re: VexPro Bearings
To be fair, you did accuse Vex of withholding damaging information from customers to bolster sales of their product. Which is is kind of a serious accusation.
Unread 11-02-2016, 16:39
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Re: VexPro Bearings
ding ding ding we have a winner... Basically steelerborn, you come off as a jerk. I'm sure you didn't intend for that but there it is. Not posting product data because it will harm their sales... mkay.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 11-02-2016, 16:43
FRC #5817 (Uni-Rex)
Re: VexPro Bearings
I said that it was only one possibility, let's say that the half inch hex bearings are rated for only 1000 rpm, I would imagine that would affect their sales. I like vexpro I think they are doing a great job.
However I don't think it is too much to ask a supplier to post the load specs for their hardware. Especially when in the workforce students will one day have to understand bearing selection and the reasons why.
I can't be the only one who thinks they should put those specs online.
team 1671
Unread 11-02-2016, 16:45
Re: VexPro Bearings
I'm sure you aren't, but there are about 100 better ways to ask for it than the way you did.
