Go to Post When I was going down that one escalator that led to the field between the buildings and getting my first look at it, I felt like Dorothy walking into Oz. - Dr. Acula [more]
Unread 11-02-2016, 15:40
SandraM6046's Avatar
SandraM6046 SandraM6046 is offline
FRC #6046 (King Tech)
Rookie Year: 2016
SandraM6046 is an unknown quantity at this point
Question Clarification for Bumpers?
My team looked at the manual and we're wondering what updates or clarification there is for the bumpers (size, restrictions, and height restrictions) on the robot.
Do we have to attach the bumpers directly to the frame or can they be above the frame on brackets?
Unread 11-02-2016, 15:44
Anthony4004's Avatar
Anthony4004 Anthony4004 is offline
Anthony4004
FRC #4004 (MARS Rovers)
Anthony4004 is an unknown quantity at this point
Re: Clarification for Bumpers?
Per R22:
"BUMPERS must be located entirely within the BUMPER ZONE, which is the volume contained
between two virtual horizontal planes, 4 in. above the floor and 12 in. above the floor, in reference
to the ROBOT standing normally on a flat floor. BUMPERS do not have to be parallel to the floor."
So yes, you can use brackets to attach your bumpers. However, they "must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame"
Unread 11-02-2016, 15:45
Anthony4004
For all the rules, see 4.7 in the robot rules.
https://firstfrc.blob.core.windows.n...-manual-04.pdf
Unread 11-02-2016, 15:47
Rookie Year: 2016
Thank you very much!
Unread 12-02-2016, 00:44
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
See Q766
Originally Posted by Q&A, Q766
  • Q. Our chassis is 6" from the ground at its highest point. Are we allowed to make our bumpers so that they start 6" above the ground and end 11" above the ground? They would start at the top of the chassis.
  • A. There is no rule that requires the BUMPERS to be backed by the "chassis", however they do have to be backed by non-BUMPER ROBOT elements (which constitute the FRAME PERIMETER). Please note that per R26: "BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-9). To be considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERIMETER." and that per R21-G they "must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame" (emphasis added).
