Go to Post No such thing as asking too much. There is such a thing as asking too fast, but not too much. - EricH [more]
Unread 11-02-2016, 16:23
amstrudy amstrudy is offline
AKA: Anja Sheppard
FRC #0900 (Zebracorns)
amstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to behold
ebm papst camera bracket
I cannot figure out how to put on the ebm papst camera bracket that we got from FIRST choice. There don't seem to be any instructions online. Has anybody used it before?
Thanks!
Unread 11-02-2016, 16:45
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
Re: ebm papst camera bracket
The assembly drawings for that bracket are available here: link. I had to install a flash plugin in order to get it to open properly, though. You will also need two servos to put it all together.
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
My team has used it a few times before. It's designed to be put together with two of the hi-tech servos that have been in the KoP in the past, so you have the ability to both pan and tilt the camera.
If I remember right... You take the big rectangular piece and use it as a base plate. The servo fits inside it and bolts on, then the circular piece mounts to the arvo output to give you the ability to pan the camera. Another servo mounts to the side of the circular piece, with the output connected to the smaller rectangular piece, which is hooked on with a bolt on the opposite side. That gives you the ability to tilt the camera. Then you fix the camera right in there.
2016: Lake Superior WFFA
