Go to Post I continue in FIRST because I'm not looked down upon for not knowing how to do something, but held up because I want to learn. - LemmingBot [more]
Unread 11-02-2016, 18:45
hwu24110 hwu24110 is offline
FRC #0988
hwu24110 is an unknown quantity at this point
Twitchy Motors
So we have another problem with the roborio (the connection issue is fixed). I noticed that the motors twitch, regardless if it is a Talon SR or VIctor SP. We have tried another schools Talon SRs and PWMs, it still twitches, so I think it may be an issue with the wiring or the physical roborio. It is not a shortage since the electronics board is mounted on a wooden board and the only wires touching the metal frame are the motor wires and the battery cables, which I am fairly sure is not causing the issue.
Unread 11-02-2016, 19:20
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Re: Twitchy Motors
What programming language?
Is it possible you're addressing motors from more than one area in your program? It's a favorite mistake I find with my students. They forget that somewhere else in the program a motor is set to 0 and in another part they're trying to run it at some speed. Causes motor twitch.
Unread 11-02-2016, 19:38
FRC #0988
Re: Twitchy Motors
I am using Java. There are only four lines of codes that tell the motors to do something.
LF.set(-stickL.getRawAxis(1));
LR.set(-stickL.getRawAxis(1));
RF.set(stickR.getRawAxis(1));
RR.set(stickR.getRawAxis(1));
I can determine these are the only lines of code that make the motors move by commenting them out. When I do that, the talons blink orange.
Unread 11-02-2016, 20:50
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Lireal has a spectacular aura aboutLireal has a spectacular aura aboutLireal has a spectacular aura about
Re: Twitchy Motors
It sounds like it is something wrong with the joystick. What joystick are you using? You should be able to recalibrate your joystick to fix it.
Unread 11-02-2016, 21:12
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Twitchy Motors
Put the robot up on some blocks of wood, and change your teleop code to this:
LF.set(-1.0);
LR.set(-1.0);
RF.set(1.0);
RR.set(1.0);
That will rule out the joysticks being a problem. I'd also double check all your code, just to be sure.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 11-02-2016, 21:44
Dan Waxman Dan Waxman is offline
FRC #0263 (Aftershock)
Rookie Year: 2016
Dan Waxman is an unknown quantity at this point
Re: Twitchy Motors
Check the battery voltage. Sometimes with brownout protection the wheels will be a bit twitchy.
Unread 11-02-2016, 22:45
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Twitchy Motors
We've seen the same behavior from victor sp's in past years. Our best guess is that they can be sensitive to noise on the PWM wire. Are your PWM wires running along side power wires?
Unread 11-02-2016, 22:58
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Twitchy Motors
Interesting, with a digital line like PWM, noise shouldn't be a big deal unless it's really, REALLY bad. Hopefully OP comes back with a response soon cause I'm genuinely curious. The only thing that hasn't been mentioned is the faint possibility that both motor controllers are incorrectly calibrated, but it is still feasible.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 11-02-2016, 23:06
Re: Twitchy Motors
Need more description of the symptoms.
For all we know the drive motors are wired into 30amp breakers, rather than 40a breakers.
Unread 12-02-2016, 00:06
FRC #0988
Re: Twitchy Motors
I have tried setting each motor to a value of 0 and it still twitches.
I do not have the robot in front of me to confirm the breakers.
We've calibrated the victors and talons multiple times. I don't think we're calibrating it incorrectly.
Unread 12-02-2016, 00:26
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Re: Twitchy Motors
Since you mention different types of motor controllers, are the correct motor controller types being initialized for each of them in the code?
Nate
Unread 12-02-2016, 00:34
FRC #0988
Re: Twitchy Motors
Yes, I had made sure of that.
Unread 12-02-2016, 09:46
Re: Twitchy Motors
Perhaps photos of your wiring setup would help identify additional potential problems/solutions.
P.S.
I do have a rookie team describing motor controller twitching, too, but they always have the robot apart when I've been visiting so I haven't been able to diagnose it yet.
Unread 12-02-2016, 13:10
AKA: Matt B
FRC #1771 (1771)
Re: Twitchy Motors
You could also post all of your code, that will help us make sure something isn't inadvertently happening.
1771- Mentor (2015)
Unread 12-02-2016, 15:42
Omer Huly's Avatar
Omer Huly Omer Huly is offline
FRC #1690 (Orbit)
Omer Huly is an unknown quantity at this point
Re: Twitchy Motors
We had a twitching talon SR... we managed to solve this by connecting the talon to another PWM port.
Since we are getting a strange error in the driver station about PWM (something like PWM 0FRC in some WPIlib).
