Go to Post It's never been about the robots. But the robots make an interesting misdirection that we all use. So its ALL about the robots. :rolleyes: - Foster [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 11-02-2016, 19:34
mattoreo310 mattoreo310 is offline
FRC #4012
mattoreo310 is an unknown quantity at this point
Permission denied
Hello,
If anybody can help with this error that would be great.
Buildfile: C:\Users\Robotics Team 4012\workspace\Getting Started\build.xml
Trying to override old definition of task classloader
get-target-ip:
[echo] Trying Target: roboRIO-4012-FRC.local
[echo] roboRIO not found via mDNS, falling back to static USB
[echo] roboRIO found via static USB
dependencies:
[echo] roboRIO image version validated
deploy:
[sshexec] Connecting to 172.22.11.2:22
[sshexec] cmd : rm -f /home/lvuser/FRCUserProgram
[sshexec] Could not chdir to home directory /home/lvuser: Permission denied
[sshexec] rm: can't stat '/home/lvuser/FRCUserProgram': Permission denied
[sshexec] Remote command failed with exit status 1
[echo] [athena-deploy] Copying code over.
[scp] Connecting to 172.22.11.2:22
BUILD FAILED
C:\Users\Robotics Team 4012\wpilib\cpp\current\ant\build.xml:67: com.jcraft.jsch.JSchException: Could not send 'C:\Users\Robotics Team 4012\workspace\Getting Started\Debug\FRCUserProgram' to '/home/lvuser' - 3: Permission denied
Total time: 4 seconds
Unread 11-02-2016, 19:50
ATannahill ATannahill is online now
AKA: Alex Tannahill
Re: Permission denied
Originally Posted by mattoreo310 View Post
Hello,
get-target-ip:
dependencies:
deploy:
BUILD FAILED
Can you tell us how you are connected to the roboRIO? ethernet or USB?
Have you changed the log-in information for the lvuser account on the roboRIO?
Unread 11-02-2016, 19:51
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Did you try anything I suggested on the other thread? My suggestion remains reimage your RoboRIO. Something is messed up with the permissions on the /home/lvuser directory, and the simplest way should be to reimage it.
Unread 12-02-2016, 07:18
FRC #4012
Fsilberberg, we reimaged the roborio but I am not the programmer. This happened after they left when I tried to deploy the program. I'm not sure if the other errors are there.
Rtfgrow, we are using usb to connect to the roborio.
Thank you both for the help.
Unread 12-02-2016, 19:18
AKA: Alex Tannahill
I want to make sure I have all the facts straight. Is this the order that things happened? Did you do anything else?
1. The programmers left
2. you reimaged the roboRio
3. you tried to deploy the code
What language are you using?
Unread 26-02-2016, 22:18
O-H
FRC #0048 (Delphi E.L.I.T.E.)
I am having similar problems and detailed what I am seeing in this post - http://www.chiefdelphi.com/forums/sh...48&postcount=9.
Any help anyone in the know could lend would be appreciated!
Unread 26-02-2016, 22:34
Landonh12's Avatar
Landonh12 Landonh12 is online now
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
He is using C++.
BUILD FAILED
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
