Go to Post The person that I would, without a doubt, would like to meet the most is my sanity. - lukevanoort [more]
Unread 11-02-2016, 17:10
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Re: 1706 Shooter Reveal
WOW, and we thought our spring shooter was ridiculous!
We did the math as well and got a number closer to 200lbs @ 5" of compression, so with an extra 400lbs and inch of compression I can safely assume this thing shoots EXPONENTIALLY harder than ours! Good job
It isn't shiny enough.
Unread 11-02-2016, 18:09
If you're both using springs it's probably closer to linear (if you're talking about force) or a power function (if you're talking about energy).
Unread 11-02-2016, 19:14
dwodrich dwodrich is offline
FRC #1706
dwodrich has a spectacular aura aboutdwodrich has a spectacular aura aboutdwodrich has a spectacular aura about
Originally Posted by Ryan Dognaux View Post
Like the power! We prototyped something similar for a linear puncher. Any ideas on how you'll get the ball into it intake-wise?
We don't have a cool cord system like yours, just rollers on top. Then we won't take the ball into the robot just hold it with the intake. Then we get the intake out of the way or we launch it through the goal.
Unread 11-02-2016, 21:36
anishde's Avatar
anishde anishde is offline
FIRST? What's SECOND?
AKA: Anish De
FRC #5123 (Mechadogs)
anishde is on a distinguished road
I can see it now - THE TOWER FIGHTS BACK.
The boulder flies into the high goal...and ricochets back out.
Unread 11-02-2016, 23:30
squad1706's Avatar
squad1706 squad1706 is offline
You can't skeet the Skoat
AKA: Skoat
FRC #1706 (Ratchet Rockers)
Rookie Year: 2015
squad1706 is an unknown quantity at this point
Ok, things to fix!
Most important, our shooter is actually more in the neighborhood of 200lbs of force. I had in my mind that the spring was a 750, when it was really a 375. So, not nearly as much power as in the video or as stated.
Unread 12-02-2016, 00:05
philso philso is offline
FRC #2587
Originally Posted by Brandon Holley View Post
While in general I agree with your sentiment about safety - I do think the word 'overpowered' could be a bit of a leap if there goal was to fire the ball in as straight a line as possible. Maybe this is their goal...
-Brando
How straight does it need to be? At some point, one passes the point of diminishing returns. A mechanical failure in a mechanism with that much stored energy is not very funny.
Unread 12-02-2016, 11:21
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
Originally Posted by squad1706 View Post
Ok, things to fix!
Based on seeing the video, I have one piece of advice, make sure your autonomous coding and driver/shooter skills are on point. I bring this up because this robot can only ever accidentally shoot a volunteer once before a head ref is going to have the "if it ever happens again your robot will be considered unsafe" conversation
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 12-02-2016, 11:42
squad1706's Avatar
AKA: Skoat
Rookie Year: 2015
Very true. What I meant in that statement that you quoted me in was sort of misleading. Yes, we are aware this is a design that has ALOT of power. We are also making sure that this device will be safe, accurate, and stable as well. We have never had this device launch in an unsafe way, and will continue to make sure it doesn't.
Thank you for your concerns though, as this is a design with many posibilities for malfunctions.
Unread 12-02-2016, 12:43
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Can I borrow that? My school is having a dodge ball tournament tomorrow and my friend has dibs on our shooter.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 12-02-2016, 14:51
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
We have a similar concept... but yours sounds like war machine when it shoots
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 12-02-2016, 20:17
jodge1706's Avatar
jodge1706 jodge1706 is offline
Captain | Driver | Bench Grinder
AKA: Gavin
Team Role: Driver
jodge1706 is on a distinguished road
We do, using rollers, it will suck the ball into the front of the shooter where the ball is housed. This rollers will actually move to get out of the way of the shooter whenever we don't need them anymore. So the intake will be attached to the arm that holds our shooter.
Just because you graduated doesn't mean you have to stop being a student....right?
2016 Championship Volunteer
2016 Robot: "MASTERKEY" | St. Louis Regional Semi-Finalists | Rocket City Regional - Spirit Award / Quarter-Finalists
Unread 13-02-2016, 21:19
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Originally Posted by RoboChair View Post
You might find the following historical articles of interest for researching more naming opportunities.
https://en.wikipedia.org/wiki/Catapult
https://en.wikipedia.org/wiki/Ballista
https://en.wikipedia.org/wiki/Petraria_Arcatinus (bow powered stone thrower)
Don't forget this!
https://en.wikipedia.org/wiki/Gastraphetes
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
