Go to Post It is one thing to be a great designer, it is another thing to be able to explain what you did, how things work, and why things happen. - Andy Baker [more]
Unread 11-02-2016, 17:48
4404 PCH Colts 4404 PCH Colts is offline
FRC #4404
4404 PCH Colts is an unknown quantity at this point
HELP!!!!!!!!!: Arm Lifting
We are having problems raising our intake arm. We have it directly hooked to a CIM motor attached to a 64:1 BaneBot gearbox. Looking for teams with similar designs to provide stall torques and/or gear ratios that are working for them
Unread 11-02-2016, 17:54
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Re: HELP!!!!!!!!!: Arm Lifting
Without knowing your whole system and wanting to give you the fun of learning this stuff yourself, you'll want to download JVN's Design Calculator. It helps even the most helpless like myself understand what we need to make our robots run and supports the fragile facade of it looking like I know what I'm doing. By comparison, you'll probably be a natural.
Unread 11-02-2016, 18:02
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
What Wil said. But for reference 4607 is running a 725:1 ratio with a Cim motor in a 4 stage Gem 500 gearbox from AndyMark, and we have a 4:1 reduction after that with #35 chain. Oh and we have 2 of those setups. I like to say we have infinite power
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 11-02-2016, 18:09
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by PayneTrain View Post
Without knowing your whole system and wanting to give you the fun of learning this stuff yourself, you'll want to download JVN's Design Calculator. ...
Getting and using the JVN design calculator is the best advice you can get!
We are using a Mini CIM and 90:1 reduction on a 24" arm.
Unread 11-02-2016, 18:23
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
At first blush a CIM connected 64:1 to a collector mechanism doesn't strike me as scary.
0) Counter-balance the mechanism with a spring or air cylinder (one should generally do this no matter what else you find IMO)
1) Check your battery, main power connections, and other electrical connections
2) Check for binding/asymmetry/drag in the mechanism
3) Make sure you greased the BB transmission
4) Make sure there's not a stupid coding issue limiting power
5) Check JVN design calculator to make sure you're not insane
You have a maximum of 337*2 watts of power
That overall reduction is... unneeded. At some point you're simply slowing yourself down, risking damaging mechanisms, and adding weight.
Unread 11-02-2016, 18:40
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
I know it's overkill, and I know it's not "infinite power", but it's more than we'll ever need. We have the weight and room for the gearboxes any they move the arm at a favorable speed, so I see no reason to change. With that said, we could easily remove a stage on the Gem and lower the gear ratio if it becomes a problem.
Reveal Video
White Paper
Unread 11-02-2016, 19:49
FRC #4404
Thanks for all the advice folks! We did some back of the envelope estimations, and are also looking into other options like the ones you listed above, but wanted to make sure we weren't going crazy. The JVN calculator will be EXTREMELY helpful as well. Thanks again!
Unread 11-02-2016, 23:15
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The single best way to figure out how much torque you need to hold a rotating arm is to buy yourself a luggage scale or a fishing scale or something.
Disconnect the arm from any gearboxes or motors so friction won't throw off your readings. Tare the luggage scale, put the rotating arm horizontal to the floor, hook the scale onto the arm somewhere and measure the weight. Multiply the weight by the distance from the pivot to the hook and you've got a fairly accurate measurement of the torque you need.
Note that you want your transmission to stall at something like 4 times this torque or better to account for losses, actually moving the thing, and not blowing breakers. JVN's calculator can help you more with this aspect of things.
Unread 12-02-2016, 05:03
DaveL DaveL is online now
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Most of our lifting arms have been pneumatic. But when I first became a mentor, we didn't know how to do pneumatics and we used a motor to power our arm in 2012.
I learned 2 things really fast; 1) don't rely on your motor's bearings for arm support and 2) any arm faster than full range of motion in under 3 seconds is very dangerous and unlikely to be accurately controlled by humans.
In the off season, we went and rebuilt that arm with a 250:1 Banebots transmission and a 2:1 sprocket reduction. (500:1 total reduction).
We learned the arm is so stiff, we needed to run the motors to move it. What's going to happen when a robot hits it or your robot runs into a wall?
We are trying AM's 50:1 transmission with a 5:1 sprocket on a 2 foot arm (250:1). This transmission has large steel gears that should back drive if hit. Hope that's slow enough without running it at 3 volts!
Unread 12-02-2016, 07:33
Hgree56's Avatar
Hgree56 Hgree56 is offline
AKA: Hunter Greene
FRC #4272 (Maverick Boiler Robotics)
Hgree56 will become famous soon enough
Our team was having a similar problem. Most of what we did has already been said before but springs help with lowering the arm more slowly and getting that original push into the air. Good luck guys!!!
2016 Indiana Tipp. District Industrial Safety Award winner
2016 Indiana Perry M. District QF w/ (3487 & 4580)
2015 Indiana Purdue District Chairman's Award winner
2015 Indiana Indianapolis District QF w/ (5403 & 4008) and Industrial Safety award winner
2015 Indiana Indianapolis, Purdue, and State Champs Industrial Safety Award Winner
2014 Crossroad GP Award Winner
2014 Boilermaker SF w/ (337 & 4213)
Unread 14-02-2016, 12:53
FRC #2976
Update: tested the arm last night. With 3 volts it moved at a reasonable speed and was able to lift 30 lbs. placed 12 inches in front of the frame!
The arm can be back driven by hand, yet there was enough friction to hold the arm in place.
Dave
Unread 14-02-2016, 14:44
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Sounds like more than enough!
