Go to Post well, our team isn't actually building a robot, we're covering our team leader in foil. - NERD12345 [more]
Unread 11-02-2016, 23:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Compressor won't turn off - PCM?
I agree - check for swarf (metal shavings) or another source of a short across the pressure switch terminals. If you can't find anything, replace the PCM, preferably working with the vendor or CTRE.
Unread 12-02-2016, 00:02
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Another thing to check: make sure the pressure switch isn't shorted out; with the compressor running, unplug the switch. If the compressor keeps running, it's a PCM issue (or swarf intrusion as some have mentioned). If not, the switch or its wiring is shorting out.
Unread 12-02-2016, 19:09
Minerbotics4827 Minerbotics4827 is offline
FRC #4827
Minerbotics4827 is an unknown quantity at this point
We have unplugged and replugged everything in three times, checking for shorts every time. We didn't find any metal shavings, and even took the PCM apart trying to find any. Even if we unplug the pressure switch while the compressor is running, the compressor stays on. We are ordering a new PCM to test tonight. Until then, we have the pressure switch plugged in as a digital input and are controlling the compressor through code in teleop while we test.
Unread 12-02-2016, 20:31
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Don't forget that for competition you need to either switch back to a PCM or put the compressor on a spike (R88 C and D).
Unread 12-02-2016, 23:32
ratdude747's Avatar
AKA: Larry Bolan
Yeah, I'd RMA that PCM. That's clearly a PCM issue.
