Go to Post The GDC probably took bets on how many posts they could get off of a random CAD render, and bonus points for how many people go insane from thinking about it! :yikes: - gallo26 [more]
Unread 11-02-2016, 15:24
mklinker's Avatar
mklinker mklinker is offline
Coach FRC4485
AKA: Mike Klinker
FRC #4485 (Tribe Tech Robotics)
mklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to behold
Pneumatic Cylinder Question
Do the rules allow firing two pneumatic cylinders from one solenoid valve? I have looked throughout the rule book and can find no reference for this.
We are planning to fire both shifting cylinders with one solenoid valve if allowed.
Mike Klinker Mentor, Tribe Tech Robotics FRC 4485
2016 Walker Warren District Semi-Finalist
2015 Indiana District Championship Semi-Finalist, Purdue District Quarter Finalist, Kokomo District Quarter Finalist, R2OC Finalist
2014 Boilermaker Regional Quarter Finalist
Unread 11-02-2016, 15:32
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Pneumatic Cylinder Question
You can definitely connect one solenoid to two cylinders, this is very common especially in the shifting application. Be sure to try and make those hoses the same length so shift time is as close to synced as possible.
Unread 12-02-2016, 00:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Perhaps you were thinking of R90:
Originally Posted by R90
The outputs from multiple valves must not be plumbed together.
That is, you can't use two solenoid valves to speed up one cylinder. There is no rule against driving multiple cylinders from the same solenoid valve, but note that if speed is too slow this way, you can speed things up by using a separate valve for each cylinder.
