Go to Post "And that right there is the Sharpie line between right and wrong. Guess which side you cut on?" - Cypher [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 08-02-2016, 17:40
Robojacks4674's Avatar
Robojacks4674 Robojacks4674 is offline
Lead Strategist
AKA: Brock
FRC #4674 (Robojacks)
Team Role: Tactician
Rookie Year: 2016
Robojacks4674 is an unknown quantity at this point
Question Question about using Mobile Data for Scouting
If my team were to theoretically purchase 7 android tablets, and get a SIM card for each, (1 server, 6 user scouts scouting EVERY qualification match for sure), if you were to give a rough estimate, how much data would you use? (using SuperScouter for a baseline example)
Unread 08-02-2016, 17:55
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Question about using Mobile Data for Scouting
It all depends on how much data you have going back and forth. How many data points per match? How big is each data point (in bits... Depends largely on the type of data)? What sort of extraneous information is passed back and forth (for example, if it utilizes an XML structure to transfer data, you have to account for all the text that makes up that structure)?
Honestly, the best way to determine this is to probably measure a small sample. Set up a proxy to send everything through that you can use to measure transfer size, then run through a dozen sample matches (all over WiFi). You should be able to figure out how much data per match per tablet is used, then calculate how much you would use for an entire event based on event size and anticipated number of matches.
2016: Lake Superior WFFA
Unread 09-02-2016, 17:38
tom23's Avatar
tom23 tom23 is offline
Android Dev wiz
AKA: Tom Orth
FRC #2729 (Storm Robotics)
tom23 will become famous soon enough
Another team I know looked into mobile data but the size was really high. I would use a short range transmission like NFC for data transfer
Unread 09-02-2016, 17:44
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
See in our whitepaper about how we use Bluetooth to communicate data from 6 Android tablets to 2 central SuperScout tablets. We then use cell data to transmit from those 2 tablets (using two different providers to improve reliability.)
http://www.chiefdelphi.com/forums/sh...d.php?t=137706
Unread 09-02-2016, 17:45
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
We'll probably use mobile data. The amount depends on your scouting system. I've made our system just send raw data -- numbers and boolean in JSON format. I suspect it'll take no more than a quarter kilobyte per robot per match. For a 100 match event, that's 150 KB total.
Head Programmer / Driver
Unread 12-02-2016, 01:21
jkoritzinsky jkoritzinsky is offline
AKA: Jeremy Koritzinsky
FRC #4786 (Nicolet F.E.A.R.)
jkoritzinsky will become famous soon enoughjkoritzinsky will become famous soon enough
I saw SuperScouter mentioned in the OP here, so I'll chime in. It uses Google Protocol Buffers to transfer data. Over HTTP, it sends the data in binary, so it is extremely efficient (less than half the size). Since Protocol Buffers do not transfer their structure information with them, that space is not needed. Also, because it is a binary format it ends up much smaller for numerical entries (which are pretty common I would think)
Additionally, if you use QR codes, you will spend nothing on data (but make sure that you transfer relatively often. Don't want the QR code to run out of space to transfer the data).
Nicolet F.E.A.R. (Team 4786) - Aerial Assist - Programming Manager
Nicolet F.E.A.R. (Team 4786) - 2015+ - Junior Mentor
SuperScouter for FRC Developer
[IMG] code is Off
