Go to Post What happens when everything becomes fully swagged out? Also, does my robot need to have collar-popping functionality to use every feature? - AlecMataloni [more]
Unread 12-02-2016, 07:39
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Build error while deplyoing to roboRio (Eclipse, c++)
Originally Posted by mattoreo310 View Post
And now we receive a new error:
BUILD FAILED
C:\Users\Robotics\wpilib\cpp\current\ant\build.xml :45: Assertion failed boolean test.
roboRIO not found, please check that the roboRIO is connected, imaged and that the team number is set properly in Eclipse
At this point we are not too sure what the problem is and are considering calling National Instruments, any help?
Thanks.
We had that error too after upgrading the image. Here's what we did:
1. Update the wpilib eclipse plugin. Make sure it's version 0.1.0.2016(something)
2. Close eclipse
3. Delete (user profile folder)\wpilib
4. Open eclipse
There was an issue with the new plugin updating the wpilib folder and deleting the folder lets it install correctly.
