Re: Shutting Down a Robot-Mounted Pi
Integral means like the battery that comes with your laptop. This topic has been done extensively elsewhere on the forum. Adding a battery to the Raspberry PI violates the rules unless you can buy a package from somewhere that has the PI and the battery packaged together. That source (store) needs to be able to sell to the general public. |
The issue is not with linux but the SD card. R-Pis have a tendency to bork the SD file system if shut down at the wrong time. I recommend to my students to have a complete clone of the working system SD card, which NEVER goes in a Pi. If the one in the Pi gets corrupted, reclone the master copy on to it, and everything is exactly as it was.
the master is made by taking the latest working pi card and shutting down properly before cloning to master. when doing software updates, have two masters. one is the last working rev, and the other is the current working rev. Also, faster and more expensive SD cards tend to corrupt less (anecdotally) Lastly, to answer the OP, I'd send a signal from the roboRio to the Pi at end of match to request a clean shutdown, then it will be powered down by the time you get to your robot during field reset. Most other cases can be covered by the onboard power switch linked to above. You still will have cases of unexpected power loss, but the less often it happens, the better. knowing how long your electronics take to boot and shutdown nicely is really important. |
All of these teams have 3D printers and are not interested in a revenue source entrepreneurs award. If nobody wants to jumps on this I'll start a company tomorrow to sell you one. |
Worse there's nothing stopping someone then from placing a really big order which means unless you have a large pile of the Raspberry PI handy... |
So you say I'm almost guaranteed to sell a few hundred to prove I can keep up with demand? I'm not hearing the problem. Adafruit will sell me 85 per order |
![]() Are you done yet? (quoting an old college professor 10 minutes into every test) Can we buy one? Remember you need a way to charge that integrated battery as well. If you sell this under COTS there's no minimum sale requirement - just that people in general can buy them. If you take this product into FIRST approval that's a more complex and lengthy process you will not complete this season. Last edited by techhelpbb : 12-02-2016 at 14:33. |
#7
In 2012 we used a linux single-board computer on our robot and had to solve the shutdown problem. There are some details in this document:
http://www.chiefdelphi.com/forums/sh...ght=Kinect+987 Our final solution assumes that you've written a program on your vision processing computer that can respond to packets it recieves from the RoboRio or other computers. Our robot computer (crio at the time) sent a packet to the vision co-processor which caused it to run the shutdown script. We triggered all of this with a button on one of the joysticks at the drive station. For what it is, it was a lot of work to get right but we didn't want that 1 in a million chance of our vision computer corrupting its file system at the wrong time. |
#8
Has anyone looked into the legality of this?
http://www.modmypi.com/raspberry-pi/...dules/ups-pico I'm going to ask on the Q&A myself tonight. |
#9
I await the Q&A response, but I expect this would not be legal, as it's not integral to the cots computing device. It's an add-on, but I suspect it is just outside the line. Could be an interesting option if they rule it legal.
#11
Also this from me in that topic: http://www.chiefdelphi.com/forums/sh...1&postcount=45 See later pages there are others on the forum about this. I don't have my fingers on the old official QA you'd have to dig that up and look but I meant this forum when I wrote this: "This topic has been done extensively elsewhere on the forum." If I really need to I am sure I can dig up that old e-mail from FIRST headquarters. Last edited by techhelpbb : 12-02-2016 at 13:55. |
#13
