Go to Post May your shirts be full of buttons, yours inspiration be plentiful, and your error messages be few. - Barry Bonzack [more]
Unread 12-02-2016, 09:54
BetaHelix's Avatar
BetaHelix BetaHelix is offline
FRC #4646
BetaHelix is an unknown quantity at this point
Spider-Man style Tower scale
The goals
Hang on the bar
Do this in 10s or less
Fit on 14in tall robot
Proposed solution
Take two small Nerf (or similar) guns, and attach grappling hooks and steel cable. Hard mount these to your frame at the corners. At the start of endgame fire both dart guns at the bar. Then use 2 CIMs to winch yourself up 22-28in and hang there.
Does any one see any problems related to legality or technical implementation?
(Assuming the hooks stay within 15ins of the frame, and are throw at non lethal velocities)
Unread 12-02-2016, 09:58
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Spider-Man style Tower scale
Center of gravity issues and the changing of the plane of your 15" rule. If your frame where to change it's orientation you would violate the 15" and incur a penalty.
Unread 12-02-2016, 10:15
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
The frame rule just says that your 15 inch plane rotates with the plane of your robot correct?
Unread 12-02-2016, 10:17
BetaHelix's Avatar
FRC #4646
But if you do it like this, the distance from your frame would decrease as you climbed
Unread 12-02-2016, 10:18
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Yes. You would need to make sure that the robot never tips vertically (such that it "drives" up the wall).
Unread 12-02-2016, 11:34
bogally99 bogally99 is offline
FRC #0159
bogally99 is an unknown quantity at this point
We had also considered a system like this, the problem with shooting darts up is that they are unreliable. Instead we are considering a telescoping arm that can just drag a hook up there. The arm doesn't have to be strong since it never takes more than the hook's force. Then in order to stay perpendicular to the wall we are going to mount the cable to the back of the frame as well as the motor.
We haven't been able to test this yet as it is the last thing we would put on our robot given the time. I would recommend that you don't focus on the lifting until you have everything else perfect. The lifting is one of the most difficult challenges and has a very small benefit. I mean you get 10 extra points for adding an entire new subsystem.
Either way good luck with this, it will be challenging.
Unread 12-02-2016, 11:43
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
The other thing is, there is no possible way to get a nerf gun to fire a dart that heavy more than 5 ft (unless you make something known as a pumpsnap)
It isn't shiny enough.
Unread 12-02-2016, 12:00
FRC #0159
That is what I was thinking about, with all that added weight from a hook you won't be very accurate and you will suffer from too little power. 5 feet may be good enough to reach the bar, but when I calculated this I couldn't even get that high.
Unread 12-02-2016, 12:08
Unless you built a pumpsnap
Unread 12-02-2016, 13:08
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
That is basically what we have. We have a solid working shooter right now so we developed a climber. Should be done tomorrow. We have 3 telescoping PVC pipes connected with surgical tubing and para cord that get winched up extended the hooks to the bar. The hooks are then attached to a separate winch with some pulleys to balance the weight. I do not know how well or even if its going to work but I should be able to tell you tomorrow.
Unread 12-02-2016, 13:10
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
I wonder if this would work.
461 Westside Boiler Invasion
45 Technokats
Unread 27-02-2016, 21:52
Golfer4646's Avatar
Golfer4646 Golfer4646 is offline
[SLFF]: The Breakfast Company
AKA: Nicholas L.
FRC #4646 (Team ASAP)
Team Role: Student
Golfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to behold
Close enough?
Unread 27-02-2016, 22:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
You can make your own nerf-like gun using PVC. I feel like a compressed air system would be illegal though, need to double-check the rules on that.
Unread 27-02-2016, 23:15
That is what a pumpsnap is
http://www.nerfitalia.it/wp-content/...RainbowMk2.png
