Go to Post PS: Sorry for derailing this thread even further. - Molten [more]
Unread 31-03-2003, 06:11
Jim Jim is offline
no team (Mcibed)
Jim is an unknown quantity at this point
Send a message via AIM to Jim
While we never could claim "KING" of the hill. We learned at regionals that if we positioned ourselves sideways to an opponent, we were an immovable force on any surface.
It wasn't the worlds most exciting strategy, but we held our ground even with us on HDPE and Wildstang on the mesh. That semifinal was incredible! If Wildstang were to get three or four more good runs at us, they may have finally nudged us off the top.
Our Auton was reliable every time. Sensors as pulse counters on the wheels: Back up out of the starting box, slight turn to face the stack, GO!. When Auton ends, start defense. Maybe you could say that we were the PITA bot (Pain in the ...)
If you are a tall robot without Auton, we'd keep you in the box for the rest of the match. If you got out we'd make it difficult for you to get to where you want to go. Sometimes that means blocking out our side, sometimes that means that we keep you over on yours.
Like I said, not very exciting, but once we figured our our strengths, it worked well.
Thanks to 65 for picking us as an alliance partner and thanks to 16 for being such a great partner, too.
Steelkilt Lives!
Unread 31-03-2003, 06:46
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
Re: Which Robot Do You Think should be King Of The Hill
Originally posted by Mike522
Which Robot do you think should be King Of The Hill.
229
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 31-03-2003, 07:38
Originally posted by Mark G
It is still really cool!!
I know team 68 uses rotations as well. Have you guys discovered how to calculate if you lose traction or if you are being pushed? Are you monitoring voltage draw? Also why do you guys use two light sensors on the same wheel? Do you guys have a problem with feedback time and the processor processing it fast enough? I guess I am just full of question for team 111 tonight... lol Great Bot as always
Lot's of questions...
1. We use two sensors placed so that their outputs are 90 degrees apart. This allows you to get accurate counting and direction info. If you bump into something or get pushed, the info is still valid and the auto mode will try to correct.
2. We do not worry about traction or loss of grip with the floor. We observed that our wheel design kept a good grip on all surfaces and the system we use (Now known as StangPS or Stang Positioning System) was able to position the robot anywhere we tell it to go within + or - 6". If auto mode was for a longer duration or over vastly different surfaces we would have to rely on other methods of determining distance traveled.
3. We are not yet employing our StangeSense current monitoring although all of the electronics are there. We are doing so well on current draw that we can easily run three or four matches on a battery. (We don't tempt fate that much though.)
4. We use an outboard processor (HC08 at 9 MHz) on the custom circuit board. It takes input from the gyro, wheel sensors, steering sensors and produces commands for the RC.
5. We have a variety of preprogrammed auto runs, 11 of which are available to be selected from the operator interface. We are also working on a Palm Pilot interface which would allow us to draw on the Palm (overlay of the playing field) where we want the robot to go and then load that into the processor. We showed some of that system in our pit at Midwest Regional via video tape.
This is geting a little involved, I will leave it up to the moderators as to whether to channel this into it's own thread. See you all in Houston.
Unread 31-03-2003, 09:31
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Originally posted by Jnadke
Yeah, but all that fancy equipment don't help a whole lot when you set the robot up backwards *grins*
We did not line it up backwards.
Hehe... sorry, didn't mean any disrespect.
Whether you meant it or not this comment was not appreciated. You clearly have no knowledge of what happened so please don't speculate.
For the people who don't know what I mean, in the semifinals of MR, Wildstangs bot ran straight into the midfield barrier during autonomous. I would assume they lined the bot up backwards so it thought it was going the other way...IMO, it was this that allowed 16 to come back in the 2nd match and win.
Allowed 16 to come back? What on earth are you talking about? 16's alliance beat us in both matches. After the first match we were down 106 to 10.
Unread 31-03-2003, 09:38
Dan-o's Avatar
Dan-o Dan-o is offline
Strategist
AKA: Brandon Rudy
FRC #1319 (Flash)
Dan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to behold
522 is a great king of the hill bot. We were paired with them during the elim's at Philly. They are a fairly small bot with a great tread style drive train and a great driver. I have seen them wedge multiple opponents off of the top of the ramp on several occasions. Great bot!!!
'03 - FRC 365 - Driver
'04 - FRC 1370 - Mentor
'05 - FRC 1493 - Mentor
'09-'11 - FRC 2975 - Mentor
'12-'13 - FRC 4029 - Mentor
'15 - FRC 1319 - Mentor
'07-'10 - Judge
Unread 31-03-2003, 10:29
Guyute Guyute is offline
AKA: John Whelan
no team (West Side BoilerInvasion)
Guyute has a spectacular aura aboutGuyute has a spectacular aura about
Send a message via AIM to Guyute Send a message via Yahoo to Guyute
45 showed they were king at Chicago along w/ 292 and 245
2nd Place in CURIE
Top 20 in the Nation
Everyone should Try HOOKAH!
Unread 31-03-2003, 10:51
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Yeah, that wasn't too impressive was it. I'm not quite sure what the cause of that was. There were rumors that it had missed it's first waypoint and drove back to get to it. Once it was back in the starting well it tried to drive in a straight line to the top of the ramp. This would cause the wheels to slip as it pushed against the side of the ramp. Thinking that it was at the top of the ramp, it drove to what it thought was the bottom of the ramp, when in reality it ran into the bar.
We need to do some more research, but if that was the case, we have a plan to fix it.
Unread 31-03-2003, 11:06
tonyargote's Avatar
tonyargote tonyargote is offline
#0059 (RamTech 59)
tonyargote is an unknown quantity at this point
Send a message via AIM to tonyargote Send a message via Yahoo to tonyargote
HAVE YOUR GUYS SEEN SWAMP THING!! It's scary. That's a king of the hill robot 4sho.
TArgote
Driver, Programmer, Webmaster
www.RamTech59.com
UCF: Ranked 13th (2nd Highest QP's in the Nation! (349))
Championship: Ranked 12 out of 73 teams in Archimedes Division, Quater finalist allied with 1108 (GO 1108!) & 868 ( GO 868!)
Unread 31-03-2003, 11:12
Powers's Avatar
Powers Powers is offline
#0710 (PAW)
Powers is on a distinguished road
Send a message via AIM to Powers
team 168 will not get pushed off the hill, but other bots can also join them up to
Team 710 PAW Alum
The team that supports the use of the word "Blatantly"
TEXAS WON THE ROSE BOWL
Unread 31-03-2003, 16:25
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Overall I actually thought it was rather impressive. It was neat in one of the matches (qf's I think) to see the robot be able to sweep the entire stack area and knock down all the stacks and then go up the ramp and take out the wall. Ingenious design.
I was only pointing out that no system is impervious to imperfection. That flaw pointed out that the system still has errors.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 31-03-2003, 16:57
Thanks, it was fun to watch it skim across the field. When we originally designed our waypoints for that program we had the wings deployed. We changed it to not unfold until we got to the ramp waypoint. That's the reason it missed the first stack. As soon as that happened we modified our waypoints to make sure that never happens again.
As does any evolving system ... and they always seems to fail at the most critical of times.
We take a lot of pride in StangPS and are extremely careful with our field setup and human player period to ensure it gets a chance to shine. I can guarantee you that at this point in the game that setup would be double, even triple, checked.
Unread 31-03-2003, 17:40
Amanda M's Avatar
Amanda M Amanda M is offline
dpl
AKA: M/C Cord
Amanda M is a name known to allAmanda M is a name known to allAmanda M is a name known to allAmanda M is a name known to allAmanda M is a name known to allAmanda M is a name known to all
Send a message via AIM to Amanda M
Well, I might be biased, but I like our robot. Once our feet are down we are pretty hard to move...
Another locking bot: 330. They stayed on pretty well.
Uhh... oh yeah! 980 was good, too
hitomi o tojite sora o miage hadashi no mama de odoritsuzuketa
kaze ni motare...
Close your eyes, look up at the sky, and keep dancing barefoot against the wind...
Unread 31-03-2003, 17:50
Software Engineer
Rookie Year: 1995
This is one area where our system really paid off. We designed that program during lunch after the alliance selection using our waypoint drawing program (WildDraw). We just plotted out a course on the field that we wanted to run and loaded it into the robot controller. We didn't even need to test it out. It worked almost perfectly. (Well, it worked perfectly in the sense that it went exactly where we told it to. It missed the first stack, but that was due to not setting a waypoint close enough to the wall). Those of us on the autonomous team were excited to finally run a new program other than just up and over the ramp.
Unread 31-03-2003, 22:46
Meyer_Shuky's Avatar
Meyer_Shuky Meyer_Shuky is offline
#0168 (The Flashbacks)
Meyer_Shuky is an unknown quantity at this point
Send a message via AIM to Meyer_Shuky
team 168 baby
The Flashbacks.......
Spirals are good for ya!
Unread 31-03-2003, 23:04
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
out of 800+ teams only 2 were speaken very highly of and this is coming after close to 19 regionals.
any other teams u think deserve the KOH title besides 111 and 45 .
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
King of the Hill Rusted_Grail Rules/Strategy 7 07-01-2003 14:40
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
