Go to Post The code won't compile if you violate the rules of the programming language...but English is more robust, it seems to work pretty well no matter how we engineering nerds mangle it! - MrForbes [more]
Unread 12-02-2016, 16:46
ICE_Bear ICE_Bear is offline
FRC #5875 (ICE)
ICE_Bear is an unknown quantity at this point
Calibrating
How do you calibrate the Victor 888 motor controller?
Unread 12-02-2016, 17:14
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Calibrating
Go to vexrobotics.com, find the victor 888, and go to the user manual.
Here's that link.
Calibration's on page 2.
Unread 12-02-2016, 19:39
FRC #5875 (ICE)
Re: Calibrating
How do you calibrate the victor SB motors?
Unread 12-02-2016, 20:00
FRC #5875 (ICE)
Re: Calibrating
thank you for your help. we figured it out.
Unread 12-02-2016, 20:06
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Calibrating
I've never heard of a Victor SB, nor a Victor motor. If you mean a Victor SP controller, same recipe. Go to a vendor (again, Vex sells them), find the product page, and look through the links, especially the "Docs and Downloads" tab. The quick start guide includes calibration procedures on page 6.
You can also get there by googling
Victor SP Calibration
The fourth hit (as of today) takes you to the quick start file.
