Stockpile
Rookie Mentor here:
What stuff do you stockpile for years to come? I would like to build a program that lasts. |
Re: Stockpile
Our classroom used to be a math room, so we had to find storage to have all our parts out of sight. We wound up with rolling locker sorta units, and each is sorted by subsystem.
Things that you'll want to have on hand:
For us, if it's not trash we save it. I'll go around our shop and take some photos of how we're set up, we've been doing it since 97. |
Re: Stockpile
Some things that are cheaper if you buy in quantity:
12 AWG Machine Tool Wire (Red + Black spools) (McMaster-Carr) Fasteners (especially 8-32, 10-32, 1/4-20) (Fastenal or whomever) Polycarbonate 4'x8' sheet (local plastics supplier) Aluminum 4'x8' sheet (thickness of .125" or so) (local metal supplier) Things that I buy strategically with an eye on having a stockpile and reusing in future years: DC Motor Controllers Other control system components for 2nd robot VersaPlanetary gearbox parts Pneumatic Solenoids (FIRST Choice every year) |
Re: Stockpile
Also important to a successful team: Thoroughly understand the "why" of each machine tool you purchase as a team, as well as recognize the institutional cost of each one. A CNC minimill might be a great idea with one year's student makeup, but two years down the road the institutional cost is now higher due to the knowledge moving out. Whatever you own, needs to have some sort of mentor/faculty training involved, or the students need to have a formalized pass-down of training year to year. |
Re: Stockpile
Ditto to what everyone else said.
I would also stock Versaframe stock in all different shapes and sizes Versaframe gussets wheels shaft collars and spacers/appropriate size pvc There are plenty more things you should stock but those are a couple that come to mind quick. |
Re: Stockpile
-Gussets of common angles and sizes. Also get some of the Vex bearing gussets, they're nice. Always buy more than you think you need. -8-32 bolts, 10-32 bolts, 5/32 rivets, and related hardware and tools. -Banebot wheels of various sizes and durometer. They're awesome for prototyping because they come in a lot of sizes and three different materials. They also hold up pretty well to the stresses of competition. -Andymark plaction wheels or Vex traction wheels. For most games, these are the gold standard for wheels. A little more difficult to work with than the KOP wheels, but it's well worth it. -0.5" hex shaft, bearings, shaft collars, and spacers. -1/8" and 1/4" lexan (polycarbonate) sheet, .09" sheet aluminum, and almost anything on this page under "sheets, bars, and strips" or "tubes for fabrication" -Literally anything Andymark sells. -CIMS, miniCIMS, BAG and 775pro motors will get you very far. Most other motor types are situational. -Pneumatic stuff. -#25 and #35 sprockets and chain, once again 0.5" hex is best in most cases. You'll never need anything bigger or smaller than #25 and #35 chain in FRC. -An arbor press. The bigger, the better. -A 0.5" hex broaching tool. You'll thank me later. -Pool noodles and red and blue nylon fabric. |
#7
Re: Stockpile
Building materials (aluminum stock and hardware, esp versaframe & gussets & rivets & nuts/bolts)
Wire, tubing, and other basic electric and pneumatic components. Wheels: We don't really buy wheels just to stockpile, but we never throw away a wheel that still has enough life left in it to serve as a prototype. Controls stuff: again, we don't usually buy anything specifically to stockpile, but everything that doesn't work out from prototyping that's still useful goes on the shelf. Actuators: We have motors and cylinders that are not up to another life on a competition robot, but we keep anything reasonably serviceable to use in prototypes. Sensors: We keep a bunch of odds and ends limit switches, range detectors, and encoders for the gearboxes we like to use. Chassis Kits: This year, we opted out of the KoP, but bought two AM-14U2s a few months before the season. This let us brainstorm ideas with a known kit before kickoff. It looks like it paid off - we've done much more with the kit than the designers ever intended. (We still have to prove that it works, though.) Do not stock up on FRC-specific items unless you are reasonably confident that you'll use them, or you have enough money to put at risk. Most items are eventually de-listed from being FRC legal; you don't want to spend a bunch of money on motors and control items that you can't use. I hope that FRC continues the policy they started this year of announcing legal motor controllers and motors in the fall, and extends it to more items and longer lead times. |
#8
Re: Stockpile
In terms of things we explicitly stockpile (on 2667 and for GOFIRST), I'd say the first thing on the list is definitely fasteners. It's just such a pain to have to go out and fine what might be the right fastener at a hardware store, plus they're really not too ridiculously expensive if you buy from some place that isn't McMaster-Carr (I like Copper State, personally). I believe we've spent around $500 on bolts from there, and that got us a full assortment of 8-32 button and socket heads up to 2" (for VEX), and a similar assortment for 10-32 and 1/4-20 bolts for stuff like FRC. This year GOFIRST bought a full set of gear ratios for the VEX VersaPlanetary line, and that was well worth it during Ri3D. I'd highly recommend gradually building up that kind of stock on your team. Keep your motors around, and try to build up a stock of the main ones (CIM, MiniCIM, BAG, 775)-- combined with VersaPlanetaries, there's not much you won't be able to make using those. Stock whatever your team plans to use to make the robot-- this might be an extrusion like 80-20, REV, or Bosch, it might be VersaFrame, or it might be raw materials like aluminum sheet or box tube. It's also a good idea to keep some polycarbonate around for electronics boards-- AndyMark sells some nice stuff with a hole pattern that's pretty great. Other motion related stuff is also good to stockpile-- like Mechvet said, pulleys, chains, et cetera are great to keep around. Keep all those extra belts from your Kitbot-- HTD is a common profile and it's easy to get pulleys for them. Even if you prefer belts, it's also a good idea to keep some chain around, both #25 and #35, since it's generally easier to prototype with. Bearings and shaft stock are also great-- 1/2" round and hex are the most common in FRC. May or may not be something you'll immediately need, but as your team starts designing more complicated mechanisms it's great to have on hand. Motor controllers are a must. Make sure you take advantage of your FIRST Choice selections every year and the vouchers in the KOP to maximize your stock of these. You can get so many for free, it's great. One of the other things I'd mention is being extremely strategic about how much you buy of things and how you store them. It's a lot easier to build a culture of keeping things organized than it is to try to force a team that's used to being messy to clean up. I love these for keeping fasteners and small stuff like bearings organized. My old team, 2220 had a bunch of ones inthat style but double sided, which I personally hate because they're generally not as durable and get crazy heavy, but these ones last forever and are generally fantastic. I think we have a dozen-ish of them right now. Highly recommended. Keep an eye out for how you can keep stuff organized as you build inventory, and know where you're going to put stuff before you order it. |
#9
Re: Stockpile
Hardware:
6-32, 8-32, 10-32, Ό-20, 3/8-16 Nuts/Bolts (Hex Cap Screws (G8), SHCS, BHCS, FHCS) (3/8 to ~3 long) Hex Nuts, Nylocks, Wing Nuts, Coupling Nuts, Aluminum Ό-20 stuff, etc. Spacers Mostly #10 & Ό ID (1/16, 1/8, 3/16, Ό, 5/16, 3/8, ½, 5/8, Ύ, 1) Some #4, #6, #8, 3/8, ½ ID, lots of VexPro ½ Hex in all lengths Rivets (up to Ό diameter) Wood/deck screws Velcro Zip Ties Duct Tape (lots of colors) Electrical Tape VHB Tape Hose Clamps All Thread (mostly Ό-20, some 10-24 & 3/8-16) Grippy Stuff (drawer liner, vet wrap, stick tape stuff) Stretchy Stuff (latex tubing, tarp straps, bungee cords, etc.) Hinges (various) Clips Pins Cable/Wire Rope Pulleys Springs Generally a hardware store Raw Materials: Aluminum (6061): Flat Bar(1/8 thick x .5, .625, .75, 1, 1.25, 1.5, 1.75, 2, 2.5, 3, 4, 6 wide) Angle (1/8 x .75, 1, 1.25, 1.5, 1.75, 2 wide) Channel (various - usually 6063) Box Tube (1/16 & 1/8 wall x 1x1, 1x2, 1.5x3, etc.) Round Bar (.25, .375, .5, .625, .75, 1, 1.125, 1.25, 1.5) (some in 7075 as well) Hex Bar (.375, .5, .625, .75, 1) Round Tube (1/4, 3/8, and ½ ID thin wall stuff to make spacers, etc.) Plastics: Polycarbonate/Lexan Sheets (0.030, 0.040, 1/16, 1/8, Ό) in 2x4 panels and some 4x8 sheets Some UHMW, Delrin, HDPE in bars and rounds, etc. PVC Pipe (various sizes) Wood: Plywood & Dimensional Lumber (2x4s, etc.) 80/20 10 Series: 1010 T-slot extrusion T-Nuts (single, double, triple) Plates, angles, linear slides, hinges, etc. 80/20 QuickFrame Series: 9000 Tube Lots of the plastic connectors in all varieties Electrical/Electronics: Wire Red/Black, Zip Wire 10, 12, 14, 16, 18 AWG, #6 Red/Black Yellow/Green Twisted CAN Bus Wire PWM Cables (various lengths) Wire Loom, Spiral Wrap, Panduit Type Plastic Wire Channel Anderson PowerPoles by the truck load (15A, 30A, 45A, Red/Black Housings) Ferrules CAN Bus connectors Wire Terminals (male/female quick disconnect, ring, etc., red/blue/yellow wire gauges) Ethernet cables (short ones like 6, 12, 18 for the robot) Circuit Breakers (120A Main, 20A, 30A, 40A) Anderson SB50 Battery connectors & associated bits and pieces (lugs for PD board, etc.) Heat shrink Red and Black tiny to ~1 on spools Speed Controllers (Talons, etc.) PD Boards VRMs PCMs RoboRIO (at least one spare) Radios (a spare or two) USB & Ethernet Cameras Switches (various toggle, button, lever, magnet, etc.) Sensors (encoders, sonar/maxbotics, IR, etc.) Batteries Pneumatics: Compressors Air Tanks Solenoids Regulators Pressure Relief Valves Pressure Gauges Nason Switches Dump Valves Air Line/Tubing Endless Brass and Push-In Fittings (in every possible configuration) Pneumatic Cylinders (as many sizes as we can Ύ, 1-1/16, 1-1/5 bore mostly various lengths) Mechanical: Motors (CIM, Mini-CIM, BAG, 775Pro, BB550, AM 9015, AM PG, Window Motors, Snow Blower, Van-Door, etc.) Gearboxes (as many as we can, ToughBoxes, ToughBox Nanos, ToughBox Minis, CIMPle Boxes, VersaPlanetaries (lots), Vex Ball Shifters, etc.) Wheels (4/6/8 AM & VEX, traction, pneumatic, mecanum, Colsen, Banebots, etc.) Hubs (AM & Vex, round bore, hex bore, bearing bore, etc.) Bearings & Bushings (Radial, Thrust, Flanged, Ό, 3/8, ½, 5/8 ID, hex bore, roller/ball bearing & bronze bushings, etc.) Shaft collars and couplings (3/8 & ½ ID mostly, round and hex bore) Acme lead screws & matching nuts fast lead/multi-start Lots of various 20DP gears in steel and aluminum to prototype with #25 & #35 roller chain and sprockets (lots of various sizes) HTD type belts and pulleys (lots of various sizes) Lazy Suzans/Turn Tables (Im not sure why) Pretty much everything AndyMark and Vex Pro sell plus seemingly half of what McMaster-Carr sells at some point or other. |
