Go to Post One of the big things in FIRST is going global. - JosephC [more]
View Poll Results: Which defenses are proving to be nastier than you initially thought?
Low Bar 15 8.57%
Portcullis 12 6.86%
Sally Port 19 10.86%
Cheval De Frise 19 10.86%
Rock Wall 10 5.71%
Rough Terrain 16 9.14%
Drawbridge 15 8.57%
Ramparts 56 32.00%
Moat 80 45.71%
Multiple Choice Poll. Voters: 175. You may not vote on this poll
Unread 12-02-2016, 17:55
anishde's Avatar
anishde anishde is offline
FIRST? What's SECOND?
AKA: Anish De
FRC #5123 (Mechadogs)
anishde is on a distinguished road
Re: Gotcha! That defense was nastier than I thought...
Interesting to see the responses...has anyone actually built the drawbridge or sally port yet?
Unread 12-02-2016, 18:11
GBK GBK is offline
FRC #1918 (NC GEARS)
GBK is a glorious beacon of lightGBK is a glorious beacon of lightGBK is a glorious beacon of lightGBK is a glorious beacon of lightGBK is a glorious beacon of lightGBK is a glorious beacon of light
A couple of things to look at on a real field. First is the rough terrain. It is a lot rougher in real life than in wood. The sally port has the nuts that hold the skin to the frame sticking out at just around 7" FIRST has shortened the bolts from what is in the drawings, but the nuts might be tough on bumpers. Also the Port Cullis will react much different on the field than the plywood team build do, due to the materials used in the movements not being wood. In all cases the steel edges are going to act different that the wood edges on everything.
