Go to Post Wait, that's exactly how it's supposed to work, isn't it. Well played GDC, well played. - alopex_rex [more]
Unread 12-02-2016, 18:53
Dolphin07 Dolphin07 is offline
FRC #5568 (Solid Rock)
Rookie Year: 2015
Dolphin07 is an unknown quantity at this point
Question Help with Vision for WebCams
Our team is running into difficulty with fluorescent lights causing a very white-washed image on our dashboard. We are using a webcam (HD 3000). Is anyone else experiencing this issue and does anyone have any suggestions on how to fix it? Any help is much appreciated!
Unread 17-02-2016, 15:45
seabasssl seabasssl is offline
FRC #3711
seabasssl is an unknown quantity at this point
Re: Help with Vision for WebCams
Could very well be an exposure problem. The way to address brightness and exposure settings of a USB camera is by using the USBcamera class, which has functions to change camera settings.
Unread 18-02-2016, 23:06
Rookie Year: 2015
Thanks for the suggestion. We did play with exposure values, as well as brightness and white balance. None of these proved successful. We decided to try a different webcam (Logitech 920), and it works beautifully. We are assuming that the Microsoft Webcam HD3000 either is not compatible with our code or the lighting in our workspace is too bright for it. Thank you again. Good luck with your bot!
Unread 26-02-2016, 20:34
kmckay's Avatar
kmckay kmckay is offline
FRC #5401 (Fightin' Robotic Owls)
Rookie Year: 2015
kmckay will become famous soon enough
Do you have any example code for this? I crash the rio when I use USBCamera and CameraServer in the same code.
Unread 26-02-2016, 22:00
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
You can manually set the white balance in Java so there's no reason you can't in C++.
Java code:
CameraServer server = CameraServer.getInstance();
cam = new USBCamera("cam0");
cam.setExposureManual(100); // exposure, 0 to 100
cam.setBrightness(100); // brightness, 0 to 100
cam.setWhiteBalanceManual(10000); // white balance, unsure what max is (10000?)
server.startAutomaticCapture(cam);
