Go to Post Our thanks does not have to come from their lips. It comes from the finished product that walks across the stage, gets their diploma and moves on to bigger and better things. - Koko Ed [more]
Unread 12-02-2016, 18:14
hwu24110 hwu24110 is offline
FRC #0988
hwu24110 is an unknown quantity at this point
Re: Twitchy Motors
These are the images
Those are 40 Amp breakers
Unread 12-02-2016, 18:28
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Twitchy Motors
The wiring looks correct to me (except for your lack of CAN). Does not having the roboRIO connected to the PDP cause any watchdog errors? Not sure...
Anyway, you could try 4 different PWM ports to see if maybe those ports are bad.
Also if you post your code we can rule out the code being an issue.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 12-02-2016, 18:42
Re: Twitchy Motors
The wiring looks good to me too.
Take a look at the Driver Station Log File after these twitches occur.
To see if the Event List or the graphs show unusual behavior.
Unread 12-02-2016, 18:43
AKA: Matt B
FRC #1771 (1771)
Re: Twitchy Motors
The new radio is 12V, the old radio is 5V.
Edit: Weird, I got an email saying a new post said that the voltage should be changed. Ignore this post I guess
Edit2: Also, when youre testing, do you have the robot up on blocks, so the wheels arent touching the ground? Its possible that they are drawing too much current.
1771- Mentor (2015)
Unread 12-02-2016, 18:58
FRC #0988
Re: Twitchy Motors
We do prop it on blocks when we test it.
I swapped the PWM ports to 4, 5, 6, and 7 and it still twitches.
package org.usfirst.frc.team988.robot;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
public class Robot extends SampleRobot {
    Joystick stickL;
    Joystick stickR;
    final String defaultAuto = "Default";
    final String customAuto = "My Auto";
    SendableChooser chooser;
    Talon LF;
    Talon RF;
    Talon LR;
    Talon RR;
    public Robot() {
        stickL = new Joystick(0);
        stickR = new Joystick(1);
        LF = new Talon(4);
        RF = new Talon(5);
        LR = new Talon(6);
        RR = new Talon(7);
    public void robotInit() {
        chooser = new SendableChooser();
        chooser.addDefault("Default Auto", defaultAuto);
        chooser.addObject("My Auto", customAuto);
        SmartDashboard.putData("Auto modes", chooser);
    public void autonomous() {
    	String autoSelected = (String) chooser.getSelected();
//		String autoSelected = SmartDashboard.getString("Auto Selector", defaultAuto);
		System.out.println("Auto selected: " + autoSelected);
    	switch(autoSelected) {
    	case customAuto:
            break;
    	case defaultAuto:
    	default:
            break;
    public void operatorControl() {
        LF.setSafetyEnabled(true);
        LR.setSafetyEnabled(true);
        RF.setSafetyEnabled(true);
        RR.setSafetyEnabled(true);
        while (isOperatorControl() && isEnabled()) {
            LF.set(-stickL.getRawAxis(1));
            LR.set(-stickL.getRawAxis(1));
            RF.set(stickR.getRawAxis(1));
            RR.set(stickR.getRawAxis(1));
            Timer.delay(0.005);		// wait for a motor update time
     * Runs during test mode
    public void test() {
Unread 12-02-2016, 19:11
FRC #0988
Re: Twitchy Motors
I do not know if anything is out of the ordinary for the event logs since I don't know what to look for. Is there anything that would be a big sign something is wrong?
Unread 12-02-2016, 19:13
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Twitchy Motors
Check main power connections and battery/battery voltage.
(didn't read the whole thread, this has been the cause of many a twitchy motor though...)
Unread 12-02-2016, 19:28
AKA: Matt B
FRC #1771 (1771)
Re: Twitchy Motors
The code looks correct also, only thing I can think of is instead of doing GetRawAxis(1), try getY(), but that shouldn't make a difference.
You said that you tried just setting their value to a constant? 0 or 1, and it still twitched? If it twitches with a value at 1, it could be a power issue, but if it twitches at 0, that sounds like a roboRIO issue.
Make sure there are no metal shavings in the PWM ports on the roboRIO.
Last thing I would try, hook up another Talon and put a new motor on it. Unplug the other Talons and comment them out. See if it twitches with just one Talon/motor.
1771- Mentor (2015)
Unread 12-02-2016, 21:32
FRC #0988
Re: Twitchy Motors
I set it to a value of 0 and we've ran the vacuum over it a few times already.
Unread 12-02-2016, 21:40
AKA: Matt B
FRC #1771 (1771)
Re: Twitchy Motors
Hm. Do the motors twitch if the joysticks are unplugged?
Also I would try reimaging the roboRIO.
1771- Mentor (2015)
Unread 12-02-2016, 21:44
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Twitchy Motors
You have a really long wire run between the battery and the PDB. This will cause a significant voltage drop under load. You should keep your wire runs as short as possible. This may or may not be causing the twitchy motor issue, but it could cause problems for you in the future.
Can you post a driver station log of the battery voltage for when the twitching occurs?
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 12-02-2016, 21:58
FRC #0988
Re: Twitchy Motors
The motors do twitch when the joysticks are unplugged.
We have tried reimaging the roborio multiple times already.
Where can I find the driver station logs?
Unread 12-02-2016, 22:08
Chris_Ely's Avatar
AKA: luckof13
Re: Twitchy Motors
This article explains how to view the logs. They are under the Diagnostics tab in the driver's station.
Just post a screenshot of one of the graphs.
Unread 12-02-2016, 23:03
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Twitchy Motors
Line resistance on a 5ft line of 22AWG PWM signal wire is about 0.08 ohms, and considering OP's cables don't even look that long, line resistance is most likely not a factor here. OP, If those are custom made cables, I'd suggest you check your terminals for faulty crimps. It's easy to mess those up. Also, try adding in your CAN runs between the PCM, rRio and PDP. It's far-fetched, especially considering the rRIO has little more than a terminating resistor for the CAN line, but I wonder if this could be a factor. Also, your breaker power runs are ridiculously long, try cutting those down, a lot.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 12-02-2016, 23:13
philso philso is offline
FRC #2587
Re: Twitchy Motors
Do you have a PWM Generator such as the AndyMark ThriftyThrottle? You can use something like that to totally eliminate the RoboRio and the software from the equation. People who fly model airplanes or helicopters often have something like this too.
http://www.andymark.com/Thrifty-Throttle-p/am-2936a.htm
