Go to Post No matter what happens to the robot we learned our lesson and we had fun. That's what matters. - David Guzman [more]
Unread 01-02-2016, 18:16
ICE_Bear ICE_Bear is offline
FRC #5875 (ICE)
ICE_Bear is an unknown quantity at this point
PWM
How do you use PWM 2 and 3 for roboRIO?
Unread 01-02-2016, 18:18
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: PWM
There's not enough information in your question to really be able to answer. What language are you talking about?
Unread 01-02-2016, 18:19
FRC #5875 (ICE)
Re: PWM
We are using Labview.
Unread 01-02-2016, 18:21
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
Re: PWM
Right click the 2 Motor vi in begin and replace it with the 4 motor vi. Now you should have the option for 4 pwm ports instead of two.
I kind of know programming
Unread 01-02-2016, 19:28
FRC #5875 (ICE)
Re: PWM
When we change 2 motor vi to 4 motor vi it makes the program not runnable. What did we do wrong?
Unread 01-02-2016, 19:36
Re: PWM
If you do a direct replacement of Open 4 Motor for Open 2 Motor where the PWM constants have already been defined, then the PWMs can end up wired to the wrong spots (and there may not be enough of them, or too many).
This is also true if you use the speed controller pull-down selector to change from a PWM to a CAN type of control. You need to remove the old PWM constants and create->constant new inputs.
When you replace a vi with another, it's safest to also delete any input constants and recreate them, so they end up correctly wired to their new input spots.
Unread 09-02-2016, 18:42
FRC #5875 (ICE)
Re: PWM
What are the constants for the FRC roboRIO project?
Unread 09-02-2016, 23:05
Re: PWM
Here's how to add a constant using the attached image as a reference.
  1. Drag an Open 4 Motor into the Begin.vi block diagram
  2. Put the cursor on the vi icon you just dropped and you'll see the input and output nodes highlighted (left of the attached image)
  3. Put the cursor on one of the input node until the cursor becomes a wirespool (on the left of the vi icon) and right-click to get a pop-up menu (seen on the right of the attached image)
  4. Navigate to Create->Constant and left-click
  5. You'll get a new constant attached to the node that is the proper type for that particular kind of node. In this case a PWM constant.
  6. The PWM constant by default starts as Invalid, so put the cursor on the new constant until the cursor becomes a hand, then left-click and choose the PWM it should be.
Unread 10-02-2016, 19:58
FRC #5875 (ICE)
Re: PWM
Where do you find open 4 motor?
Unread 10-02-2016, 20:14
Re: PWM
It's in the Robot Drive palette:
  1. Right-click on any white space and you'll get the palette popup
  2. Put the cursor over the WPI Robotics Library at the bottom
  3. The top left icon is a folder for RobotDrive, move the mouse over that
  4. You'll see Drive Open 4 Motor
  5. Left-click and drag it to the block diagram
Unread 11-02-2016, 17:46
FRC #5875 (ICE)
Re: PWM
Is there any thing else we need to do to get it working?
Unread 11-02-2016, 22:59
Re: PWM
I'd suggest posting your Begin.vi and Teleop.vi here for us to check for you.
They are both located on you PC in the Documents folder under LabVIEW Data and then in your 2016 Robot Project folder.
You can post attachments using the Manage Attachments button on the Reply to Thread page.
Unread 12-02-2016, 18:23
FRC #5875 (ICE)
Re: PWM
A Victor SP is attached to PWM 0 that drives the rear left motor and PWM 1 is connected to rear right. A Victor 888 motor controller is connected to PWM 2, running front left and the PWM 3 is running front right.
Unread 12-02-2016, 19:46
Re: PWM
There is a little anomaly in Begin.vi with both
- the constants for PWM 0 and PWM 1, and
- the Inverted flags
They still have the labels from previously being part of an Open 2 Motor.
I'd recommend that you delete those four constants and do a create constant for them again.
After you've gotten new constants there, turn on the label for each of them by hovering the cursor over them and right-clicking to get the popup menu and choosing Visible Items -> Label (You can drag the labels around to better places too if you would like.)
With the Open 4 Motor there are also two more Inverts located along the bottom edge of the Open 4 icon that you need to create constants (and labels) for.
An issue is that because you had constants left over from the 2 Motor, they reverse only one of the motors on the left side (I think the left rear). So the left side motors would be fighting each other.
So, make sure to Invert both Left side motors (make them T for true).
If when you test the robot you find that the front and back are reversed, then just reverse all the Inverts and make the Left side motors False and the right side motors True.
Unread 12-02-2016, 20:01
FRC #5875 (ICE)
Re: PWM
Thank you for all your help. our programming is going well now.
