Re: Help With Max and Min on Sliders
I assume you're talking about the four analog values on the Basic tab of the default Dashboard program?
That program is written in LabVIEW. To change it, you'll need to have LabVIEW installed and you'll have to be able to use it. Just create a new Dashboard project and modify those controls to have the range you want them to.
You can type numbers directly into the white boxes to the right of the sliders, and they aren't limited to the 0-5 range. So you might be able to do what you want without making any changes to the Dashboard program.
