Go to Post Everyone's bored, what else do we have to do in the off season? - StephLee [more]
Unread 11-02-2016, 22:59
ajhammond ajhammond is offline
AKA: AJ Hammond
FRC #5931 (Bots of Prey)
ajhammond is an unknown quantity at this point
Exclamation Rookie team lost only programmer and need help.
We built a robot that has a 6 wheel drive system or tank drive without tread and we need help coding the robot to work with a Xbox controller and our shooting arm to work with a joystick. I have tried to learn how to use eclipse and have figured out a little bit but not enough. Would anybody be willing to teach me at least the driving portion so I can teach others on my team and do the arm on my own or help me get the code done for this year and I will learn on my own later?
Unread 12-02-2016, 13:56
aaronjeline aaronjeline is offline
Aaron
FRC #1719 (Umbrella Corporation)
aaronjeline is an unknown quantity at this point
Re: Rookie team lost only programmer and need help.
Hey, I can try to help out. Can I take a look at what code you have? Or do you not have any?
Unread 12-02-2016, 14:50
Beeker's Avatar
Beeker Beeker is offline
AKA: Joe
FRC #4377 (BC. Blaze)
Rookie Year: 2015
Beeker is an unknown quantity at this point
I would start with Brad Miller's videos. Pretty much will get you going step by step.
https://www.youtube.com/playlist?lis...wtlgnvhGObeKzp
Unread 12-02-2016, 17:48
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
If you're not set on using specifically java, python is a pretty easy language to learn. Especially if you're a beginner.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 12-02-2016, 19:27
AKA: AJ Hammond
We had a robot donated to us for demos that has octocanum/butterfly drive system and our programmer got the code set up but did not teach anyone how to do it before he left. That is the only code we have and it is for a joystick and we are using a xbox controller for drive and joystick for shooting.
Unread 12-02-2016, 20:15
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Given that you're at the end of week 5 with no programming done, you need to take stock of your resources. Do you have anyone who knows anything about programming in C, C++, Java, Python, or Labview? If so, use that language. If one of the first three, go through the screenstepslive pages for the language; they'll show you how to set up a tank/arcade style drive and even control some fairly basic arms and intakes. They even have some full-up samples ready to drop onto a robot if you're willing to wire to the same channels they used. National Instruments has similar resources for LabView. I'm not familiar with the Python resources, but I know they're out there. You should be able to get through the basics based on these tutorials and then come back to CD or another support site with more specific questions.
Unread 12-02-2016, 20:55
mikets's Avatar
mikets mikets is online now
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
I think the fastest is to take one of the sample code that resembles most to your robot and make minor modifications to it to match your robot. You should be able to have a runnable TeleOp by this method. Then you need to prioritize what you need to get working next and add code for each subsystems one at a time. With your current situation, I would give up autonomous.
Unread 12-02-2016, 21:05
AKA: AJ Hammond
Originally Posted by mikets View Post
I think the fastest is to take one of the sample code that resembles most to your robot and make minor modifications to it to match your robot. You should be able to have a runnable TeleOp by this method. With your current situation, I would give up autonomous.
We do not need autonomous just need TeleOp, Correct. But we do not have any code whatsoever and everybody on our team knows almost nothing about coding. Where do I go to get sample code I have eclipse and all the first stuff installed/
Unread 13-02-2016, 00:40
AKA: AJ Hammond
Where do I find the sample code?
Unread 13-02-2016, 02:50
mikets's Avatar
Software Engineer
If you have Eclipse and all FRC stuff installed, you can click "File->New...->Project" then you will find at the bottom "WPI Robot Java Development" and underneath that you will see "Example Robot Java Project". Select that and click "Next". Then you have a whole list of example robots to choose from. If you are planning to have a drive base that does tank drive, you may want to look at the "Tank Drive" project. Please look through the list and find a robot that most resemble to your robot.
Unread 13-02-2016, 03:01
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
For XBox programming, Team 4276 created a small class that maps the XBox buttons to their respective buttons and axes. Hope this saves you some time.
XBox.zip
File Type: zip XBox.zip (324 Bytes, 26 views)
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
