Go to Post The kit of parts is a hundred yards of denim. - StuartV. [more]
Unread 13-02-2016, 03:22
Nitay's Avatar
Nitay Nitay is offline
Moving FIRST Forward
AKA: Nitay Sheffer
FRC #1574 (MisCar)
Nitay is an unknown quantity at this point
Bumper rules
Hello there,
Do you know if that's possible to put the wood of the bumper all over the frame but to put only two 8" bumper sections on both side of the front side of the robot?
Thanks,
Nitay
MisCar 1574
Unread 13-02-2016, 05:56
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Bumper rules
If I understand what you are asking the answer is no. Your 8 in section has to be noodle backed with wood.
Unread 13-02-2016, 06:43
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumper rules
A piece of wood is not a BUMPER. So if you add wood to the outside of your "frame", that extends your FRAME PERIMETER to include those pieces of wood - and it would be included in the 120" measurement and the ROBOT weight. And then you have to install complete BUMPERS (wood, noodles, cloth covering, numbers) outside the wood pieces.
(since 2004)
Unread 13-02-2016, 09:29
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Bumper rules
No, but if it works OK for you, you could put wood just inside your frame perimeter at the gap in the bumpers. It would then be part of the robot (and count towards weight and CAW), but might meet the functional requirement that made you ask the questinon.
Unread 13-02-2016, 22:05
DonRotolo's Avatar
Back to humble
FRC #0832
Smile Re: Bumper rules
Maybe ask your question again?
I think you want to know if you can have a gap in your bumpers. Yes, you can.
Unread 13-02-2016, 22:21
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Bumper rules
Basically have your bumpers with 8"sides at each corner if your basic shape with sting is a rectangle. Any gap in between the corner bumpers is totally allowed to be any length unless the entire side of you frame perimeter is less than eight inches.
Bumpers have to exist between 4"-12" and can be offset
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
