Go to Post The low bar will make your electronics team cry. - Joe G. [more]
Unread 13-02-2016, 09:49
Kevin Pai's Avatar
Kevin Pai Kevin Pai is offline
FRC #5964 (Praetorians)
Rookie Year: 2015
Kevin Pai is an unknown quantity at this point
Witholding Allowance Rules
After the build season, we can keep 30 pounds of "fabricated" parts after putting away our robot. Are motors that were just attached to other pieces considered fabricated? Are motors included in this 30 pound limit?
Unread 13-02-2016, 09:56
Re: Witholding Allowance Rules
Any COTS item like motors that are part of an assembly are included in the withholding limit.
Separate COTS motors like new in the box except for wire connectors unattached to anything else would not be counted.
Unread 13-02-2016, 10:11
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Withhold allowance is a perfect example of what we should eliminate bag and tag.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 13-02-2016, 10:31
SamM SamM is offline
FRC #5842 (Royal Robotics)
SamM is just really niceSamM is just really niceSamM is just really niceSamM is just really niceSamM is just really nice
To piggy back on this, how are the COTS rules interpreted with respect to gearboxes? My assumption is that an assembled versa planetary is not COTS because you can't buy them assembled, but a PG71 with motor is COTS, regardless of whether or not we bought the motor and gearbox separately because it is possible to buy them together?
"The universe is probably littered with the one-planet graves of cultures which made the sensible economic decision that there's no good reason to go into space--each discovered, studied, and remembered by the ones who made the irrational decision." -Randall Munroe, XKCD
Unread 13-02-2016, 10:39
nuggetsyl's Avatar
FRC #0025
Another great example of why we need to get rid of bag and tag. These rules are unenforceable. If FIRST is not worried about who wins or loses they should not worry about stuff like this.
11 VCU winner
12 MAR Mt Olive
red is for team 348
Unread 13-02-2016, 10:58
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Just because it is not strictly enforced does not mean the rule is useless. Gracious professionalism - follow the rules even when no one is watching.
If the motor was not purchased attached, then it is fabricated. You can have extra motors outside the hold back for spares, but they must be just the motor with changes allowed by R13-D.
If you can buy it pre-assembled, then it is COTS. No different between sheet of metal and chassis.
IMHO, it is hard to have an assembled gearbox not be Fabricated because it usually requires attaching a motor. The gearbox with a motor are the exception.
Unread 13-02-2016, 12:45
The versa planetaries are designed such that you can assemble a gearbox without the motor, then attach the motor and/or mounting plate later.
We were also wondering if we need to clean the grease off of the gears, or if it is sufficient to disassemble the gearbox, but leave the grease?
I miss the old 'SPARE PARTS' rule.
Thanks
Unread 13-02-2016, 12:48
I say bring the gearboxes disassembled to the competition, assign a few students to assembling them during the practice rounds. After the competition, include the gearboxes in the bag with the robot so you can use them at the next competition without having to assemble them.
Unread 13-02-2016, 13:12
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Thanks
When purchased the gears are oiled, so Id say grease is fine. Since they come unassembled in the box, just make sure to bring them that way and then add your stages once you get to your event.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 13-02-2016, 21:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Not quite. While COTS items with wire connectors added are counted as COTS for purposes of including on this year's robot (Exception R13 D), they are not exempt from being included in the withholding allowance (R18 only has two stated exceptions, though bumpers are an implied exception to bag and tag under R15).
