Go to Post A good engineer will never stop learning. From his peers, technicians, and competitors. The field is just to vast for any one person to know it all. - Mr. Mike [more]
Unread 13-02-2016, 09:59
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld is an unknown quantity at this point
Elastic Potential Energy Stored in Surgical Tubing: What are the legal limits?
We want to project our arm that will hook on the castle tower's bar. We want to do this vertically using surgical tubing to lift the arm until it hits the stop at the top of the arm's travel. It never gets "airborne" and stays completely within the confines of its mechanism. Our question is: Is there anything prohibiting using surgical tubing, stretched and secured at the arm's base, as the means of extending the arm in the last 20 seconds. (we will have a latch mechanism in place to be sure that it won't release until our driver hits the button.) Thank you.
Unread 13-02-2016, 10:02
AngryCalculator's Avatar
AngryCalculator AngryCalculator is offline
looking for the 7/16 wrench
AKA: Andy Gothro
FRC #2910 (Jack-In-The-Bot)
Team Role: CAD
AngryCalculator is an unknown quantity at this point
Re: Elastic Potential Energy Stored in Surgical Tubing: What are the legal limits?
Nope. It should be fine; 2910 plans on using it too.
"who relabeled the white lithium grease as spray-on coffee creamer??"
Unread 13-02-2016, 10:07
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
You are specifically allowed to do this as per R35
Originally Posted by Rules
R35 Non-electrical sources of energy used by the ROBOT, (i.e., stored at the start of a MATCH), shall come only from the following sources: A. compressed air stored in the pneumatic system that has been charged in compliance with R79 and R80, B. a change in the altitude of the ROBOT center of gravity, C. storage achieved by deformation of ROBOT parts,
D. closed-loop COTS pneumatic (gas) shocks, and E. air-filled (pneumatic) wheels
What you need to be concerned with is R9
R9 ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS.
Inspectors will look very closely at your mechanism to ensure that it is safe at all times. This includes when it is being transported on/off the field as well as in the pits, etc.
___________________
- Tennyson, Ulysses
Unread 13-02-2016, 11:02
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Regarding R9:
If there will be a lot of tension put on the tubing, then you will need a safety mechanism in case the tubing breaks. Basically unplanned sudden release of stored energy must be taken into account.
In the past, encasing the tubing in tube would suffice. Make sure the outside tube has a separate attachment so that it won't go flying off either.
Unread 13-02-2016, 19:38
FRC #5523
Thanks. Looking forward to seeing how you use it, too.
Unread 13-02-2016, 19:40
FRC #5523
Thank you. Just what we needed. Good advice, too.
FRC #5523
Originally Posted by rich2202 View Post
Regarding R9:
Great idea. Thank you. Didn't think of that.
Unread 13-02-2016, 19:52
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We have an assembly that works. We abandoned our climber due to our winch being all messed up though.
Unread 13-02-2016, 20:24
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
From a practical standpoint, you probably don't want to stretch the surgical tubing much past twice its natural length; beyond this it tends to stretch inelastically*, especially if held there for a long time.
* that is, a permanent stretch, from which it will not return to its original length.
Unread 13-02-2016, 20:37
FRC #5523
Very important point. Thank you so much.
