Go to Post ... so I have to ask: ... Are you nuts? - I hope you are - as crazy as Dean :^) - KenWittlief [more]
Unread 13-02-2016, 12:20
BadonskyJ56 BadonskyJ56 is offline
FRC #4716
BadonskyJ56 is an unknown quantity at this point
Connected to Radio, Not Roborio
Hey CD,
I am able to deploy my code to the robot, but can only connect to the robot radio, and not the roborio. On my drive station, communications and robot code is red, however I can ping it through cmd. Other programmers' computers are able to connect to the driver station. What can I do to fix this?
Thanks.
Last edited by BadonskyJ56 : 13-02-2016 at 12:27. Reason: Forgot to add in additional information.
Unread 13-02-2016, 12:44
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Connected to Radio, Not Roborio
On the radio, is the Ethernet cord for the roborio plugged into the port closest to the power plug? If not, try it there.
Unread 13-02-2016, 13:01
FRC #4716
I tried that, but I encountered the same issue as before.
Also, here is a screenshot of the drive station:
Unread 13-02-2016, 13:24
Make sure the Windows firewall is turned off.
Unread 13-02-2016, 13:32
Turn off all firewalls and anti-virus.
Disable all NICs except for the one you are using for the robot (you can add them back in after you get it running).
Unread 13-02-2016, 17:02
Try giving the roborio a fixed IP address of 10.TE.AM.2
In your case, that would be 10.47.16.2
Unread 13-02-2016, 22:11
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
I was experiencing the same problem today.
We could deploy code, ping the RIO, go to the roboRIO web interface, and view the Axis camera connected to the 2nd ethernet port.
But the driver station would not connect.
Firewall was disabled, all other networks except for the Wireless were disabled.
The fix we found was to reset the roboRIO itself, and then the driver station would connect. Not the best solution, but it worked.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 14-02-2016, 00:52
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
We actually just ended up switching back to the old radios for practice. The new ones are just too unstable for use, especially when you need consistent connections. Hopefully FIRST gets this worked out by competition, otherwise there are going to be major issues with field connectivity the first few weeks
Team 4488 - Mentor 2013-2016
Unread 14-02-2016, 00:56
AKA: Matt B
FRC #1771 (1771)
Can you elaborate on that?
Other than the long boot times (~1 minute) for the new radio, after it gets configured we haven't noticed any trouble connecting to the radio. The problem I've been noticing has been between the radio and the roboRIO. (But really it's just the driver station, because we can always ping things).
That's just my experience with it so far; would like to hear other's experiences with the radio.
Edit: That said, I'm sure the long boot times will make turnaround time between matches fun...
1771- Mentor (2015)
Unread 14-02-2016, 02:35
MooseGoose MooseGoose is offline
FRC #0610
MooseGoose is on a distinguished road
We were having the same problem even after we disabled our firewall. We ended setting an exception for driverstation.exe in our firewall and it worked perfectly.
Also, try disabling all of your network adapters except for the wireless adapter to make sure the Driver Station is using the wireless network adapter.
Unread 14-02-2016, 07:51
Did you try hitting the Reset button on the RoboRio after the Radio has booted up?
Unread 14-02-2016, 14:47
aaronjeline aaronjeline is offline
Aaron
FRC #1719 (Umbrella Corporation)
aaronjeline is an unknown quantity at this point
Can I see your Driver Station settings panel?
Unread 14-02-2016, 15:01
The actual root cause of the DS not connecting to the roboRIO is the mDNS resolution on the new radio not working right. It's still possible to ping, but the mDNS address won't resolve, which causes the DS to not connect. Switching to the old radio makes all those problems go away, and DS to RoboRIO connections become much more reliable. For practice, its just not worth dealing with the issues with the new radio. Hopefully competition doesn't have those issues.
Unread 14-02-2016, 16:02
edong4273's Avatar
edong4273 edong4273 is offline
Team 2375's Very Own Dong
AKA: Edmund "Dong" Dong
FRC #2375 (Dragon Robotics)
Rookie Year: 2015
edong4273 is on a distinguished road
Besides the long boot time, our team has had no issues with the new radio.
Unread 14-02-2016, 19:55
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
We are also having this issue. +1
The sooner we get behind schedule, the more time we have to catch up.
