Go to Post That wheel appears to have been forged deep within the fires of Mount Awesome. - viking1902 [more]
Unread 13-02-2016, 00:08
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
CAN Talon and Bang Bang Controller
Has anyone had success with a bang bang controller with the CAN Talon speed controllers?
Our results were less than spectacular. The lag time for reading and setting the talons was noticeably slow so that you could tell even by listening that the motor was rotating over a large range of speed. I don't recall the graph values but the results were were over a large range.
We were also using an unloaded motor. The motor was on a bench with nothing attached to the shaft.
Any thoughts would be great to consider.
Thanks
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 13-02-2016, 00:48
Jared Russell's Avatar
Taking a year (mostly) off
Re: CAN Talon and Bang Bang Controller
Are you closing the loop onboard the Talon or on the roboRIO?
Unread 13-02-2016, 00:53
Originally Posted by duane View Post
The lag time for reading and setting the talons was noticeably slow... We were also using an unloaded motor
http://www.chiefdelphi.com/forums/sh...49&postcount=8
Look at bullet points 3, 4, and 5 (phase lag, moment of inertia, controller period). That's why your results were less than spectacular.
You could improve your results by adding a shooter wheel (increase moment of inertia) and increasing the Talon broadcast frequency (decrease the phase lag).
But if you have CAN Talon, why aren't you using its built-in speed controller?
Unread 13-02-2016, 13:08
duane's Avatar
Umm, huh? Esplain? I've been over the API, I didn't notice a built-in speed controller?
I'll look again, but a hint would be great.
Duane Murphy
Mentor - Software
Unread 13-02-2016, 13:09
duane's Avatar
How would I close the loop in the Talon?
@Ether indicates a built-in speed controller. I've not noticed that, I'm looking ...
Duane Murphy
Mentor - Software
Unread 13-02-2016, 13:15
duane's Avatar
Are you referring to
SetControlMode(kSpeed);
Hmm, that could be useful!
Duane Murphy
Mentor - Software
Unread 13-02-2016, 14:13
Unread 13-02-2016, 22:16
duane's Avatar
Thank you! We are having some success with using the Talon in these modes!
Duane Murphy
Mentor - Software
