Go to Post it's flattering, but a little scary, because I don't know if I'm ready to be an inspiration! - MissInformation [more]
Unread 31-01-2016, 22:25
Phildirt Phildirt is offline
AKA: Phil McDowell
FRC #5502 (Cobrots)
Rookie Year: 2015
Phildirt is an unknown quantity at this point
scaling the castle
The rules state that a robot has scaled the tower if it has the lowest portion of it's bumpers above the low goal at the conclusion of the match. It does not state that it has to remain there for any period of time after the end of the match.
Can anyone confirm that the robots do not need to remain on above the goal after the match for any period of time?
Thanks
Unread 31-01-2016, 22:26
New Lightning's Avatar
New Lightning New Lightning is offline
Master of Tactics
AKA: Scott Hasek
FRC #1987
New Lightning has a spectacular aura aboutNew Lightning has a spectacular aura about
Re: scaling the castle
Not sure on the actual rule number just that they have to remain there for enough time for the refs to know for sure that your robot has in fact climbed the tower. I.E. it is clear enough that your robot has indeed gotten its bumbers above the low goal.
Unread 31-01-2016, 22:30
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
The final assessment of ROBOTS having SCALED or CHALLENGED the TOWER is made five (5) seconds
after the ARENA timer displays zero (0), or when all ROBOTS have come to rest following the conclusion
of the MATCH, whichever happens first
so maybe
you also want to make sure your robot will not roll back down the ramp if you are challenging the tower
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 31-01-2016, 22:35
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
At the end of 3.3.1 the rulebook says:
Originally Posted by 2016 Game Manual
The final assessment of ROBOTS having SCALED or CHALLENGED the TOWER is made five (5) seconds after the ARENA timer displays zero (0), or when all ROBOTS have come to rest following the conclusion of the MATCH, whichever happens first.
While it is not strictly required that the robot stay above the low goals for five seconds after the end of the match, this is probably a good design goal to eliminate any uncertainty in when the refs happen to notice that your robot has come to rest or not.
Unread 31-01-2016, 22:36
snoman's Avatar
one could argue it has not come to rest if it is slowly creeping down
Unread 31-01-2016, 22:41
5 seconds, or rest, whichever comes first. If you aren't sure whether you want the refs to make a judgment call, bear in mind that the refs seem to be being instructed NOT to give the teams the benefit of the doubt, and plan accordingly.
Unread 13-02-2016, 15:53
Hugekase Hugekase is offline
FRC #1359 (Scalawags)
Team Role: Student
Hugekase is an unknown quantity at this point
so maybe
There is a little bump at the base of the tower that is there to hopefully stop your robot from falling backwards off of it. On the lines of scaling, i'd make sure that you can actually lift that weight without it snapping, falling down, then you losing your robot, because i'm pretty sure that is going to happen at least once or twice during the games.
Unread 13-02-2016, 21:27
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
If you're sliding down the tower 5 seconds after the end of the match, but it's still above the low goal, you're good.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
