Go to Post the truth is that a 'bot is only as complicated as you make it. - RogerR [more]
Unread 13-02-2016, 16:40
ICE_Bear ICE_Bear is offline
FRC #5875 (ICE)
ICE_Bear is an unknown quantity at this point
Portcullis Thickness
We are wondering how wide the portcullis itself is. If we want to have a hook that grabs the portcullis, how wide should it be? We know that the gap is 5 in tall and that it is 3'8" wide, but what's the measure of the thickness of the portcullis?
Unread 13-02-2016, 17:01
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Portcullis Thickness
P DOOR PLASTIC (from Field Component PDF)
1. Material: 1/8" Clear Polycarbonate
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 13-02-2016, 17:10
FRC #5875 (ICE)
So that is the only thickness in the entire thing?
Unread 13-02-2016, 17:14
Yes from what I can tell..
https://www.youtube.com/watch?v=HsvsOI5jV-s
Check 7:30 where he lifts it
ctt956 ctt956 is online now
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
I don't think that's the whole thing, that's just the thickness of the polycarbonate on each side. There is a steel grate sandwiched between the two sheets of polycarb.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 13-02-2016, 17:18
FRC #5875 (ICE)
So we were wondering how thick the steel grate was. We're trying to make a hook that can go under the port cullis and pick it up and possibly also fit under the sally port.
Unread 13-02-2016, 17:21
FRC #5875 (ICE)
Looking at that video, it seems to definitely be thicker than 1/8"
Unread 13-02-2016, 17:22
There is no steel grate its all polycarb..I still think its 1/8 thick single polycarb sheet
Unread 13-02-2016, 17:24
EricH EricH is online now
There is no steel grate.
This. Also reference http://www.chiefdelphi.com/forums/sh...ght=portcullis.
Unread 13-02-2016, 17:26
FRC #5875 (ICE)
The manual quotes "The door is constructed of a steel frame with a 1/8 in. thick polycarbonate sheet covering the opening in the frame."
Seeing WITH the polycarbonate sheet COVERING the opening in the frame implies that 1/8 is not the entire thickness.
Unread 13-02-2016, 17:28
Covering the opening of the (portcullis) frame, which is correct it does not mean two sandwiched sheets, keep in mind costs one sheet suffices. They would not use two sheets when they can simply paint grates on.
Sally port uses two sheets of polycarb for wood pattern print to be sandwiched between
Unread 13-02-2016, 17:30
FRC #5875 (ICE)
Did you look at the link to another forum? Because on that forum, they said that the polycarbonate sheet jut has bars PAINTED onto it, but that steel is under it and someone else said that there's an aluminum grid on the back of the polycarbonate sheet
Unread 13-02-2016, 17:31
FRC #5875 (ICE)
So it may not be sandwiched, but one side might have a steel/aluminum grid.
Unread 13-02-2016, 17:32
The polycarb is backed at the bottom edge by an ~ 1"x1" square steel bar.
I'll see if I have a photo of the Kickoff field to show it.
P.S.
The bar is just the bottom edge of the metal frame holding the polycarb.
Here's a photo: http://www.chiefdelphi.com/forums/at...0&d=1453761170
Unread 13-02-2016, 17:34
FRC #5875 (ICE)
So with the steel, does it have one or two sheets of polycarbonate covering it? In other words, is the steel sandwiched between two sheets or uncovered on one side.
