Go to Post So we get to hear the likes of Copioli, Baker and Patton yuk it up? This should be good. - Ricky Q. [more]
  #31   Spotlight this post!
Unread 12-02-2016, 23:17
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Twitchy Motors
Originally Posted by evanperryg View Post
Line resistance on a 5ft line of 22AWG PWM signal wire is about 0.08 ohms, and considering OP's cables don't even look that long, line resistance is most likely not a factor here. OP, If those are custom made cables, I'd suggest you check your terminals for faulty crimps. It's easy to mess those up. Also, try adding in your CAN runs between the PCM, rRio and PDP. It's far-fetched, especially considering the rRIO has little more than a terminating resistor for the CAN line, but I wonder if this could be a factor. Also, your breaker power runs are ridiculously long, try cutting those down, a lot.
I am not talking about the PWM cables, I am talking about the ~10ft of 6AWG power wire from the battery to the PDB - like you mentioned at the end of you post.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
  #32   Spotlight this post!
Unread 12-02-2016, 23:36
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: Twitchy Motors
Seconded. I wouldn't run long feed cables like that unless I had to. At least tie them up so they're not flapping in the breeze (at least in the one picture it looked to be catching a wheel ).
  #33   Spotlight this post!
Unread 13-02-2016, 01:50
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Twitchy Motors
Pretty sure his team left the power wires long knowing that this is just a test board and they will shorten them to fit the final configuration of their electronics... We'll take a look at it when his team visits us again this weekend.
"A genius is just a talented person who does his homework" T. Edison
  #34   Spotlight this post!
Unread 13-02-2016, 15:26
hwu24110 hwu24110 is offline
FRC #0988
hwu24110 is an unknown quantity at this point
Re: Twitchy Motors
  #35   Spotlight this post!
Unread 13-02-2016, 17:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Twitchy Motors
Voltage dropping that low in such a 'spikey' shape screams main power issue or battery issue.
  #36   Spotlight this post!
Unread 13-02-2016, 17:52
FRC #0988
Re: Twitchy Motors
I swapped out the battery cables for shorter ones and switched out the battery. I still experience twitching.
  #37   Spotlight this post!
Unread 13-02-2016, 17:56
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: Twitchy Motors
What terminals are you using for the 6awg connections?
Is there any wiggle in any of the 6awg connections?
Is there any wiggle in any of the PCM/robot controller hookups?
Have you run a load test on any of your batteries? (like a battery beak)
  #38   Spotlight this post!
Unread 13-02-2016, 18:11
FRC #0988
Re: Twitchy Motors
The terminals are labelled Burndy 6 Str Cu Blue Die 374 or 7.
I don't feel any wiggle from the 6 AWG connections
I don't feel any wiggle from the robot controller connections either
We don't have a battery beak.
  #39   Spotlight this post!
Unread 13-02-2016, 19:13
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Twitchy Motors
Personally, I don't think the batteries are the cause of the twitchy motors, mainly because they are twitching even when the code is set to give them a value of 0. That leads me to think there is either a short in the PWM wires, causing it to send a false signal to the Talon, or the roboRIO is malfunctioning.
That being said, having loose connections aren't good. And the voltage drop isn't "good", but 9 volts won't shutdown everything.
hwu24110: Could you take a video of the motors twitching, with the joysticks unplugged and the code having the motors set to 0? If you could also get the video of the Talons that would be helpful.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
  #40   Spotlight this post!
Unread 13-02-2016, 19:34
FRC #0988
Re: Twitchy Motors
https://www.youtube.com/watch?v=nj-J...ature=youtu.be
I note that when one side moved, it would always move in that direction. The other side of the robot when it twitches moves in the other direction.
  #41   Spotlight this post!
Unread 13-02-2016, 20:38
AKA: Matt B
FRC #1771 (1771)
Re: Twitchy Motors
Is your driver station showing any errors?
Is your PDP hooked up to the CAN? It seems like it isn't hooked up because the lights are flashing on it.
Do you have any non PWM speed controllers you can test? (So a Talon SRX, and test it over CAN)
1771- Mentor (2015)
  #42   Spotlight this post!
Unread 13-02-2016, 20:55
FRC #0988
Re: Twitchy Motors
THe only error that is showing up is that there isn't a controller connected
Today I hooked up the PDP to a PCM that is connected to the Roborio (The team wanted to test pneumatics). I can take photos of it tomorrow if you suspect there is something wrong with the wiring.
I have a few Jaguar Controllers but I have no experience with CAN wires.
  #43   Spotlight this post!
Unread 13-02-2016, 21:14
andrewb1999 andrewb1999 is offline
FRC #1369
andrewb1999 is on a distinguished road
Re: Twitchy Motors
We have also been experiencing the same twitching motors problem lately. We do not think it is an issue with the electronics as it does not twitch when the robot is enabled in autonomous. We are going to check the joysticks tomorrow and see if that could be the issue for us.
  #44   Spotlight this post!
Unread 13-02-2016, 23:07
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Re: Twitchy Motors
After watching the video, I would swear that you are running into the same issue that our bot was last year that I posted in this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=134694
Our issue is only when using PWM 0 (very bad) and 1 (not bad, but still present). Moving to 2 & 3, the issue cleared up. Our random fires were even in Disabled mode and sometimes lasting for 3 or 4 seconds at a time. Just for fun today, we tested the wiring this year using PWM 0 & 1 and the problem is still present with all new wiring/motors/controllers/code.
As a side, I'm assuming that your 4 motors are really 2 sets of 2 motors. Wouldn't you want to use a Y-cable on each pair so that they are getting the same signal at the same time and just calling them LEFT and RIGHT (or similar) in the code?
Nate
  #45   Spotlight this post!
Unread 14-02-2016, 01:27
FRC #0988
Re: Twitchy Motors
I've already tried swapping the ports 0, 1, 2, and 3 with 4, 5, 6, and 7.
As this was a test board, I didn't feel like scrounging around the PWM bin for Y cables. If you feel like that is the issue, I might try it out tomorrow.
