Go to Post These folks have bigger hearts than most. I think they grow them that way in Indiana. - JaneYoung [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 13-02-2016, 17:04
CPotvin CPotvin is offline
FRC #2637
CPotvin is an unknown quantity at this point
Exclamation CAN Talons Randomly Stop Working?
Yesterday, and today we have been attempting to troubleshoot a problem with the CAN Talon SRXs. Basically, what is happening is we are able to enable and drive our robot for somewhat random periods of time before the Talons stop working. When the talons stop working they show that they are receiving a neutral signal, and we have no control over them, although we can still control our intake system which is using PWM Sparks. Also, last night when we were troubleshooting the robot would have 3 motor controllers go neutral, while one would go forward til the motor it controlled overheated, and turned off, so we switched that Talon and now they all go neutral. The timing seems to be consistent in the form of they malfunction at intervals of a minute (ie. 1 minute, 5 minutes, 6 minutes).
If anyone can let us know how to fix this, and whether it is a programming or electronics problem that would be greatly appreciated.
Unread 13-02-2016, 19:50
Mineboy2300's Avatar
Mineboy2300 Mineboy2300 is offline
Drive Captain
AKA: Benjamin Louttit
FRC #2637 (Phantom Catz)
Team Role: Driver
Mineboy2300 is an unknown quantity at this point
Cool Re: CAN Talons Randomly Stop Working?
Yeah that happened to my team too. I just told electronics and programming to fix it.
2015 - Programing, Drive
2016 - Drive Captain, Electronics
2017 - Drive, Electronics
2016 - Finalist2nd Place San Diego Regional
Quarterfinalist 8th Place LA Regional
Quarterfinalist 8th Place Archimedes FRC Championship
2015 - Semifinalist 3rd place Central Valley Regional
Semifinalist 3rd Place LA Regional
Unread 13-02-2016, 21:10
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
How is the wiring on the CAN bus? Is it serial from the RoboRio to the PDP, with the PDP termination set? In other words, no Star formation and proper termination?
Did you check the firmware version of all your CAN devices?
Find the first motor controller in the series (from the RoboRio) that is causing you problems. Temporarily rewire so that one is farther along the chain. Does that make any difference? If so, you might have a bad controller or flaky wire.
Q: How many Programmers does it take to change a light bulb?
A: None. It is a hardware problem.
Q: How many Mechanical people does it take to change a light bulb?
A: None. They think it is a software problem.
I am guessing this one is a hardware problem. Software tends to fail in predicable ways. It either works, or it doesn't. Flaky hardware is more likely the cause of random problems.
Try this test:
1) Put the robot on blocks (so it doesn't move)
2) Write some code to feed the drive motors at 50% for the entire teleop period.
3) Wait 2 minutes.
Repeat 3 times the run/wait cycle 3 times.
Do the motors quit? If so, it is a hardware problem.
Unread 15-02-2016, 11:42
HolyHacker335 HolyHacker335 is offline
FRC #4945 (Titanium Wrecks)
Rookie Year: 2015
HolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud of
Wow. This is concerning as we want to use SRX's on CAN this year. Did you give all your controllers UNIQUE ID's? Sorry if that is a dumb question, but the docs indicated that the roboRIO could deal with multiple controllers without them. But I would NEVER do that myself. Jus sayin.
Dave
Unread 15-02-2016, 11:46
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Had the same issue.
Update the firmware, we're running on 2.0.
Make sure they all have different IDs on the web page of your Rio.
We got 13 CAN Talons on our robot and everything works perfectly now.
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
