Go to Post They didn’t have to help me. But they did. I have gained so much respect for all the mentors in FIRST from that point on. - Arefin Bari [more]
Unread 13-02-2016, 15:47
Amit3339 Amit3339 is offline
B B BumleB
FRC #3339
Amit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to behold
Talon Stable RPM Check
We used the code of the Talon CAN rpm to reach a certain rpm every time but having a problem to check if the rpm is stable. We programmed a block that check's if the rpm is stable for 4 times( with a clearance of +-100) but were wondering if there's a better for doing this check?
Thanks in advance!
2016- Team Captain, Driver & Programming Crew Member
Championship Curie Sub-division Winners| Curie division
Regional Winners | Israeli Regional
2015- Driver & Programming Crew Member
Championship Carson Sub-division Winners| Carson division
Excellence in Engineering Award sponsored by Delphi | Israeli Regional
2014- Driver & Programming Crew Member
Unread 13-02-2016, 21:19
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Talon Stable RPM Check
The big question is whether four queries is enough to demonstrate stability. Plot the curves of your motor speed response over time to determine whether your system is underdamped (oscillates, though eventually converges) or critically or overdamped (does not oscillate). If you are critically or overdamped, your plan is proably adequate. If your system oscillates, measure the period of that oscillation (in terms of feedback counts), and make sure that your stability criterion includes at least that many samples.
Unread 13-02-2016, 21:24
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
I am almost 100% certain your motor speed will NOT be stable. Especially when a different battery is put in your robot.
You are better off varying motor power to "maintain" a speed corridor.
Unread 13-02-2016, 22:25
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
From this, I understand that they are using the internal PID of the Talon to maintain speed, not depending on a voltage setting:
Originally Posted by Amit3339 View Post
We used the code of the Talon CAN rpm to reach a certain rpm ..
