Go to Post Look at 71's 'walking' bot from last year. One dosn't need wheels/track to move. All you need is an idea. - Jack [more]
Unread 13-02-2016, 21:39
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
Connecting Raspberry Pi to network?
Is there any thing saying that it is not allowed to have a Raspberry Pi have a WiFi adapter to connect it to the the robot's wifi network? I was planning on using 1 of the 2 ethernet ports on the router for the network camera (other for the roboRIO, and connect the Pi to the robot's network wirelessly so my team didn't have to buy a network switch and wait for it to be delivered.
Unread 13-02-2016, 21:49
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: Connecting Raspberry Pi to network?
I'm 100% sure that wouldn't be allowed or work at competition.
John Fogarty
Unread 13-02-2016, 21:56
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
I highly encourage you to check out R63 to determine whether or not it would even be legal.
Even if it were legal, remember that the radio is programmed to be in bridge mode at competitions. Teams have no access to the WPA keys used by the field, so even if you got it working back home, once you got to the competition, you wouldn't be able to connect to that network anymore.
I'm right 90% of the time, so why worry about the other 3%?
Unread 13-02-2016, 23:48
JohnM's Avatar
FRC #5854 (Glitch)
Ah yeah, forgot about this.
Thanks!
Unread 14-02-2016, 08:02
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Actually, you do have access to your key. But, since you shouldn't be connecting to the FMS wifi network with other devices, I won't tell you how.
Unread 14-02-2016, 08:45
dpotteiger dpotteiger is offline
FRC #2377
Rookie Year: 2015
dpotteiger is an unknown quantity at this point
You could purchase a mini switch as (http://www.amazon.com/Linkskey-5-Por...dp/B001BEFRBQ), power it through your VRM (careful to make certain it is connected to the correct voltage and polarity). Connect an Ethernet cable between one of the switch outputs to the available radio port. Then connect your camera and pi to the other two using Ethernet cables.
