Go to Post I think CD is worth about 3 billion in Google stock. Talk about one hell of a fundraiser! - Joe Matt [more]
Unread 13-02-2016, 19:05
cantdecide cantdecide is offline
FRC #5773 (YAFL Mechatronics)
Rookie Year: 2016
cantdecide is an unknown quantity at this point
Member function as Task
I'm using the Task class in WPILib to poll for IMU data at the moment, and in doing so I've discovered that I can't cast member functions to a FUNCPTR or a VOIDFUNCPTR. To solve this, I created a static class which holds an IMU instance and has a static function that calls the instance's update method. That did it, but now I have more methods that I'd like to call in the background. I figured that creating a class for every member function is not a very extendable solution, so my question is, how can I create Tasks with member functions? Or am I missing something and can cast a member function to a FUNCPTR? Do I even need to cast functions to FUNCPTRs? The online examples I saw casted functions to FUNCPTRs, and directly passing functions as arguments throws a compile-time error.
Unread 13-02-2016, 22:25
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Re: Member function as Task
The technique is to create a static function in your class. The first parameter to your function is this. In the function, dispatch to the member function using the this pointer. This technique is a kind of a thunk.
class MyClass
  private:
    static void sProcessTask(MyClass* self, int someParam);
    void DispatchTask();
    void ProcessTask();
void MyClass::sProcessTask(MyClass* self, int someParam)
  self.ProcessTask(someParam);
void MyClass::DispatchTask()
  Task myTask = new Task("MyTask", sProcessTask, this, someParam);
void MyClass::ProcessTask(int param)
  // do something on task
(Warning: Uncompiled and untested)
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 14-02-2016, 06:12
Rookie Year: 2016
Thanks, that works.
Unread 14-02-2016, 11:13
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
You can use a member function but you'll have to pass an instance to Task. I've looked in the Task source and it should work, since it forwards all of its arguments to thread. Thread internally detects if you gave a member function pointer and uses the first argument as the instance to call the function from.
class MyClass
  private:
    void ProcessTask(int param);
  Task myTask = new Task("MyTask", &MyClass::ProcessTask, this, someParam);
&MyClass::SomeFunction is a pointer to a member function.
Unread 14-02-2016, 14:33
class MyClass
  private:
I'm not a very big fan of the Task class... There are some weird pieces of WPILib which have APIs which are trying to make Linux look like VxWorks, and Task is one of them.
You can do this in 1 line.
::std::thread my_thread(::std::bind(&MyClass::MyMethod, this, arg1, arg2));
If you want to delay starting the thread:
::std::thread my_thread;
my_thread = ::std::thread(::std::bind(&MyClass::MyMethod, this, arg1, arg2));
We use ::std::thread for all threads we start, and it works wonderfully.
