Go to Post The 48 defensive DNA lies dormant in the drive train. It's impossible to forget. - Koko Ed [more]
Unread 13-02-2016, 13:53
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
Using previous years' radios as a network switch
I know this might be a better question for QA, but I'm curious if anyone has done this in the past or could point out a rule that explicitly disallows this:
I want to use the D-Link router from the 2015 as a simple network switch, no wireless broadcasting. Thoughts?
ORB Haow!
Unread 13-02-2016, 14:01
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Using previous years' radios as a network switch
QnA it.
R59 Ethernet-connected COTS devices or CUSTOM CIRCUITS may connect to any remaining Ethernet port on the Wireless Bridge but must not transmit or receive UDP packets using ports 1100-1200 with the exception of ports 1130 and 1140.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 13-02-2016, 21:46
gbear605's Avatar
gbear605 gbear605 is offline
Scarebear
FRC #1768 (Nashoba Robotics)
gbear605 is an unknown quantity at this point
By rule 63, "No form of wireless communication shall be used to communicate to, from, or within the ROBOT, except those required per R57 and R62 (e.g. radio modems from previous FIRST competitions and active Bluetooth devices are not permitted on the ROBOT during competition)."
You aren't using it for wireless communication, but the example is part of the rule, so it seems to be disallowed.
Unread 13-02-2016, 23:24
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
This rule deals specifically with wireless communication, op is asking about a non-wireless application.
(2015-?): 973
(2012-2015): 955
Unread 14-02-2016, 01:28
Captain_Kirch Captain_Kirch is offline
Alumni
AKA: Aaron Kirch
FRC #1625 (Winnovation)
Captain_Kirch is a jewel in the roughCaptain_Kirch is a jewel in the roughCaptain_Kirch is a jewel in the roughCaptain_Kirch is a jewel in the rough
Last I checked a 10/100 network switch would work, and they cost like $10-$15 U.S. That may be a better option.
Unread 14-02-2016, 02:54
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
I was also going to suggest this. It also wouldn't use up a port on your VRM.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 14-02-2016, 08:00
Are you powering it with magic smoke?
Unread 14-02-2016, 08:43
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
While you can turn off the radio on last year's adapator,and make it conform to no other wireless rule, it can be confusing to inspectors and field people. Since cost of not really an issue better to use a non wireless capable switch. They also have the advantage of initializing faster on power up.
Unread 14-02-2016, 11:05
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
No, I meant that you could use the more readily available 12v ports on the PDP.
Unread 14-02-2016, 11:13
As long as it survives being powered erratically, between 6 and 12.5v....
Not recommended.
