Re: Labview Main.iv Help
Those are all good suggestions. Also, when you have the error window open, it lists all broken VIs in the top list. If you scroll to the top, the ones with the red X are broken because of a wire or parameter issue. The ones with out an X are broken because of the dependency. So if you try to fix the red X's that will fit all of the ones above.
Greg McKaskle |
A simple way to do this if you are not using Vision would be to just put a disable diagram around the vision code. If Vision is broken it would allow you to deploy the rest of the code.
