Go to Post Ah AndyMark and your $2 a piece pool noodles - mlantry [more]
Unread 13-02-2016, 22:33
bowmanb bowmanb is offline
AKA: Bruce Bowman
FRC #3991 (KnightVision)
bowmanb is an unknown quantity at this point
programming for brownout avoidance
Our team is using a 6 cim drive for the first time and we are of course finding it quite easy to brown out when approaching full throttle from a stop and in turns in high gear.
I don't want to discuss the relative merits of 6 cim vs. 4 cim. The team wanted to do this and I lost the argument.
Ive looked in all my usual places for this and have come up empty.
The question is: In LabView how do we:
  1. access the PDB data on current and voltage
  2. implement a "governor" routine using this data to compute a scaler to limit our motor power to keep the current draw under the brownout threshold.
Unread 14-02-2016, 08:19
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: programming for brownout avoidance
Does this help?
In LabVIEW, you can read the current on a PDP channel using the PDP Channel Current VI found on the Power pallete.
https://wpilib.screenstepslive.com/s...24166/l/289498
Regarding implementing a governor, how about this:
1) Process that reads the voltage, and adjusts a "Power Factor" variable. For example, when voltage is > 9 volts, Power Factor = 1. When it drops below that, the value declines.
2) In your process that sets the speed of the motors (let's say the value is Speed), multiply that number by the Power Factor variable (Speed * Power Factor).
Unread 14-02-2016, 08:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
how do we:
I guess you could tell the students that removing a CIM from each side will implement a governor to keep the current under the brownout threshold.
But then the programmers wouldn't get to have so much fun
Good luck!
Unread 14-02-2016, 09:48
We just finished putting joystick ramping on the drive to help with the rocking -- in case the drivers want it. It will also help with surge current and is perhaps simpler than the previously described algorithm. You could even decide to keep a running average of voltage or use the voltage faults to increase the ramp each time you get one. Of course this SW stuff is just doing the same thing as teaching the drivers to be a bit smoother on the stick. Also, SW can't fix loss due to long wires, weak crimps, or excessive loss due to friction, and those mods are of course way better than simply avoiding deep voltage dips.
If you want to do a ramp, the PID palette has an output limiter or you can build your own.
Greg McKaskle
Unread 14-02-2016, 12:02
AKA: Bruce Bowman
Originally Posted by rich2202 View Post
Does this help?
Thanks! Can't believe I missed the Power Palette.
Do you think this process would work best in Periodic Tasks or Teleop?
Unread 14-02-2016, 14:27
I have no idea of the differences between Periodic Tasks and Teleop. Our team uses C++, and everything is done in TeleopPeriodic.
Unread 14-02-2016, 20:12
If you want to check it each time you update the motors, then doing it in the same place might make sense.
If you are using Command and Control, that is likely in the Drive Controller Code. Otherwise it is likely in the TeleOp code. Unless you are doing it at a slower rate, I wouldn't Periodic Tasks.
Greg McKaskle
Unread 14-02-2016, 20:53
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
I'll second this. Joystick ramping is a really simple way to avoid voltage dips that can cause brownout. We always use this code for each of our motors. If you make the rate large enough (we usually allow dead stop to full speed in .1 seconds) the drivers won't even notice.
Unread 14-02-2016, 20:59
Originally Posted by Caleb Sykes View Post
If you make the rate small enough...
If you make the rate large enough...
Unread 14-02-2016, 21:28
HolyLandBrand HolyLandBrand is offline
AKA: Texan
HolyLandBrand will become famous soon enough
How do you program this in java? Do you just use the getVoltage() method from the PDP class.. does that method give you the information you need use joystick rampinG?
Unread 14-02-2016, 21:35
If you are using CAN TalonSRX they have built-in adjustable ramping.
If not, just use something like this:
http://www.chiefdelphi.com/forums/sh...19&postcount=5
Unread 14-02-2016, 21:40
You are correct. I have edited my previous post. I got it backwards because in our code we don't refer to the rate itself, but rather the time it takes to go from 0 to full, like how I described above. So our full speed time (as we call it) must be made small enough so that the drivers do not notice.
