Go to Post God bless the camera. That's all I gotta say. - Bharat Nain [more]
Unread 14-02-2016, 10:24
Programming191 Programming191 is offline
Programming191 is an unknown quantity at this point
Angry Help with constant code crashing
Whenever I run my program on eclipse the robot code crashes before even starting. The robotInit() method does not even run. We have tried commenting out all of our code yet this does not seem to solve our problems.
Here is the riolog output:
➔ Launching «'/home/lvuser/FRCUserProgram'»
etc....
Unread 14-02-2016, 10:38
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
Re: Help with constant code crashing
The unspoken rule: Post your code before asking for help
(for real though we can't tell what's going on unless you give us your code, since there is no output. It looks like you're using C++, and since there's no output, I'd suggest deploying again)
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 14-02-2016, 11:07
I have attached a zip folder containing my code. Thank you for your help.
Unread 14-02-2016, 11:39
Jaci's Avatar
Rookie Year: 2015
My first guess would be that the "CougarLib" dependency isn't compiled and/or loaded on your RoboRIO. This would cause a fault at startup, which I don't believe is picked up by RioLog.
Jacinta R
OpenRIO : Owner
Unread 14-02-2016, 11:42
I found the issue. I was trying to write to a log file and their was an error in the way I was doing it. Thank you for your help!
Unread 14-02-2016, 11:57
Jaci's Avatar
Rookie Year: 2015
No problem, I'm glad the issue is resolved c:
Jacinta R
OpenRIO : Owner
