Go to Post Consider yourself mentored, you have learned a lesson: "Don't stick your hands in icky things." - Amanda Morrison [more]
Unread 14-02-2016, 12:03
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
pic: #TeamTablet
Unread 14-02-2016, 12:04
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: pic: #TeamTablet
very neat, any tech details on what's is going on here?
Unread 14-02-2016, 14:08
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
This is beautiful. Great set up!
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Unread 14-02-2016, 15:17
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
Looks like the strategy team has their scouting under control this year?
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 14-02-2016, 15:24
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Which tablets are those? They kind of look like the $50 Kindle tablets?
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 14-02-2016, 18:21
AKA: Alex
FRC #1126 (SparX)
Answering as many questions as I can with this post:
- The 6 identical tablets are the $50 Kindle Fire HD 7in, running CM 12.1. The other two are some sort of refurb lenovos we bought last year.
- We have an inverter that takes the 12v robot batteries and converts it to 120v AC to charge the tablets if we have no access to an outlet.
- There is an Anker 10 port usb charger, so that we only need one outlet at a time.
- We are running a custom scouting app.
Should be all of the questions. If you have more, feel free to ask.
Unread 15-02-2016, 11:16
BSEE, MSEE, JD
AKA: employed
Very cool, thanks for the rundown.
Unread 15-02-2016, 16:45
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
We have a very similar setup this year. How are you handling the process of data? Are you sending the data from the scouts to a "master" tablet? Are you posting/syncing to the cloud at all?
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 15-02-2016, 17:14
AKA: Alex
FRC #1126 (SparX)
It is stored locally to a SQL server and then pushed to a GAE NDB server when internet is available. The tablets can also retrieve from this server to get up-to date info on both our alliance partners and opponents. We also use the GAE bulkloader to get info into a .csv that we can analyze in either Tableau or Excel
