Go to Post Define "surgery". I think we have enough close calls with "surgery" as it is. Thank god for disable dongles. - geeknerd99 [more]
Unread 14-02-2016, 13:21
3205patriots 3205patriots is offline
FRC #3205
3205patriots is an unknown quantity at this point
Re: Robot class cannot be instantiated
I narrowed down the subsystem, but I don't understand what the issue could be within it:
package org.usfirst.frc.team3205.robot.subsystems;
import org.usfirst.frc.team3205.robot.RobotMap;
import org.usfirst.frc.team3205.robot.commands.armStart;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.SpeedController;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.command.Subsystem;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboar d;
public class Arm extends Subsystem {
// Put methods for controlling this subsystem
// here. Call these from Commands.
private DigitalInput armUpperLimit;
private DigitalInput armLowerLimit;
private SpeedController armMover;
private Encoder armEncoder;
public Arm(){
armUpperLimit = new DigitalInput(RobotMap.ARM_UPPER_LIMIT);
//armMiddleLimit = new DigitalInput(RobotMap.ARM_MIDDLE_LIMIT);
armLowerLimit = new DigitalInput(RobotMap.ARM_LOWER_LIMIT);
armMover = new Talon(RobotMap.ARM_MOTOR);
armEncoder = new Encoder(0,0, false, Encoder.EncodingType.k4X); //CHANGE THE ENCODER PORTS
public void initDefaultCommand() {
// Set the default command for a subsystem here.
//setDefaultCommand(new MySpecialCommand());
setDefaultCommand(new armStart());
public boolean isUpperLimitSet(){
return armUpperLimit.get();
// public boolean isMiddleLimitSet(){
// return armMiddleLimit.get();
public boolean isLowerLimitSet(){
return armLowerLimit.get();
public void moveUp(){
armMover.set(RobotMap.ARM_SPEED);
public void moveDown(){
armMover.set(-RobotMap.ARM_SPEED);
public void stopMoving(){
armMover.set(0.0);
public void resetEncoder(){
armEncoder.reset();
public int getEncoder(){
return armEncoder.getRaw();
public void updateSmartDashboard(){
SmartDashboard.putNumber("Arm Encoder", getEncoder());
SmartDashboard.putBoolean("Arm Upper Limit", isUpperLimitSet());
//SmartDashboard.putBoolean("Arm Middle Limit", isMiddleLimitSet());
SmartDashboard.putBoolean("Arm Lower Limit", isLowerLimitSet());
SmartDashboard.putNumber("Distance", armEncoder.getDistance());
