Go to Post I understand that I'm in the minority when it comes to these things, so when the coverage switches to one these stories I exercise my right to change the channel. - Karthik [more]
Unread 14-02-2016, 13:33
CoachC's Avatar
CoachC CoachC is offline
AKA: Jim Cetnarowski
FRC #5247 (Red Devil Robotics)
Rookie Year: 2015
CoachC is an unknown quantity at this point
attachment for Cim 217-3351
Im looking for a shaft attachment for a Cim 217-3351. I can use either a round rubber belt or a chain. The application is light torque.
Thank you in advance
Unread 14-02-2016, 13:40
Knufire Knufire is offline
Re: attachment for Cim 217-3351
EDIT: Ah, you're referring to a BAG motor. You probably want to use: http://www.vexrobotics.com/versaplanetary.html.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 14-02-2016, 13:44
iambujo iambujo is online now
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
I believe you are referring to the BAG motor, correct?:
http://www.vexrobotics.com/217-3351.html
If so, the best way we have made use of all the smaller shaft motors in the past is to put them in a Vexpro versaplanetary gearbox. You have many output and gearing options at that point. The gearbox comes with the mounting kit and collars to use pretty much all of the legal motors.
http://www.vexrobotics.com/vexpro/mo...planetary.html
You can assemble them with 8mm (CIM) output shafts, 1/2" hex, 1/2" round, 3/8" hex etc. Just make sure you order all the parts you need including the ring gear kit per stage if you're adding stages - and lubricate the stages with white lithium grease.
Unread 14-02-2016, 13:50
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
I'm assuming you are directly driving the BAG motor with no gearbox. We've successfully used FTC axles, collars, wheels, etc. on the output shaft of a plain old BAG motor, but I'm also assuming that you want to attach a sprocket to drive the chain. In that case the best thing you could do is put a 1:1 VersaPlanetary box on the motor. It will not change the motor, except in length and it will give you a 1/2 hex shaft (or 3/8, if that's what you want to use) to put on whatever part you need to. You can then put on the sprocket or belt pulley that you want on it.
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
CoachC's Avatar
Rookie Year: 2015
Thanks for the quick response. I saw those same products on Andymark but the Cim motor in question doesnt have a Keyway on the shaft. Is a smooth shaft.
Thanks again for the quick responses. i appreciate your help
Unread 14-02-2016, 13:52
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Keep in mind that a chain spinning at 14,000 rpm is not going to be quiet or very safe, so a guard of some sort would be insurance against danger.
Unread 14-02-2016, 13:55
Just to avoid confusion, the motor you are referencing isn't a CIM motor, it's a BAG motor.
