PART REQUEST - 3-7/8 Hex Bore BaneBots Wheel
Hello everyone,
I'm representing rookie FRC team 5810 from Santa Fe Springs, CA. Very recently we have discovered a need for ~4 inch hex bore wheels and are looking for the 3-7/8 BaneBots wheels. However, I can't seem to find them on the BaneBots website. Is there any Los Angeles region team willing to sell or trade us for those wheels? We have a very large amount 1-7/8 "green" wheels that we could trade for or otherwise pay in cash (we're on a super tight budget so I wouldn't like to ship anything) Thanks everyone! |
Re: PART REQUEST - 3-7/8 Hex Bore BaneBots Wheel
Lots of us miss those wheels but it looks like they've been discontinued. That being the case they aren't a Commonly available Off The Shelf (COTS) part so can't be used on this year's FRC robot.
If you're looking for a softer, low load wheel like the Banebot wheels were, I'd suggest looking at some of the AM Stealth wheels: http://www.andymark.com/product-p/am-2647_blue.htm
These are around the same durometer as the old blue BB wheels. |
These wheels from Andymark also come close. (oops Knufire beat me to it!!)
http://www.andymark.com/product-p/am-2647_Blue.htm ( 50A durometer) Also available in black http://www.andymark.com/product-p/am-2647_Blk.htm (60A durometer) and gray http://www.andymark.com/product-p/am-2647.htm (77A durometer) "Stealth Wheels" hex hubbed..... 4" good luck!! |
#7
Example 1: A Team orders two (2) ROBOT grippers from RoboHands Corp. and receives both items. They put one in their storeroom and plan to use it later. Into the other, they drill “lightening holes” to reduce weight. The first gripper is still classified as a COTS item, but the second gripper is now a FABRICATED ITEM, as it has been modified. Example 2: A Team obtains openly available blueprints of a drive module commonly available from Wheels-R-Us Inc. and has local machine shop “We-Make-It, Inc.” manufacture a copy of the part for them. The produced part is NOT a COTS item, because it is not commonly carried as part of the standard stock of We-Make-It, Inc. Example 3: A Team obtains openly available design drawings from a professional publication during the pre-season, and uses them to fabricate a gearbox for their ROBOT during the build period following Kickoff. The design drawings are considered a COTS item, and may be used as “raw material” to fabricate the gearbox. The finished gearbox itself would be a FABRICATED ITEM, and not a COTS item. Example 4: A COTS part that has non-functional label markings added would still be considered a COTS part, but a COTS part that has device-specific mounting holes added is a FABRICATED ITEM. Example 5: A team has a COTS single-board processor version 1.0, which can no longer be purchased. Only the COTS single-board processor version 2.0 may be purchased. If the COTS single-board processor version 1.0 is functionally equivalent to its original condition, it may be used. Example 6: A team has a COTS gearbox which has been discontinued. If the COTS gearbox is functionally equivalent to its original condition, it may be used. |
#9
I didn't realize that these wheels are of questionable legality! I certainly want to make sure we get past inspection at our event so it looks like we will be avoiding them.
Big thanks to everyone for the suggestions and help. |
#10
However, if AM were to discontinue the sonic shifter then I would be able to use mine that has a hole in it - because it is still 'functionally equivalent'. Now I'm going to hope Andy Mark starts bumping the product number every year so I don't have to buy new transmission parts to replace the ones we've had to modify. |
#11
I stand corrected. It looks like FIRST has relaxed the COTS rule from my last run-in with it. If can find a BaneBots wheel, unmodified, go for it.
Footnote, AndyMark used to go so far as to keep obsolete versions of things "in stock" but tell everyone to buy the modern version just to allow teams to use the older version they already owned. |
#13
