Go to Post Forget Pool Basketball or Pool Volleyball, it's time for some Pool Rack n' Roll! - Conor Ryan [more]
Unread 14-02-2016, 17:47
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: Dual encoders
Originally Posted by Caleb Sykes View Post
My team is running a tank drive setup this year, and have added an encoder onto each side. We are also using the NavX for angle measurements. We will have a variety of methods that rely on angle measurements from the NavX and distance measurements using one or both encoders.
However, I am wondering if there is really any benefit to having both encoders. If for distance we just take a raw average of both measurements, we are basically getting slightly more precision in exchange for a doubled failure rate. It seems to me that unless you are using two encoders to sense angles in place of a gyro (or some sort of fusion) there is almost no benefit to having dual encoders.
How does your team integrate dual encoders into the code? Does anyone just mount/use a single encoder?
In industry, we would actually use 3 encoders and then always select the midvalue one.
Just as we say:
- With 1 sensor, you don't know that you're wrong.
- With 2 sensors, you know you're wrong but aren't sure which is correct.
- With 3 sensors, you always know which one is wrong and which is right
(From a single-fault-tolerance perspective)
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
