| Let's swap data! |
#31
Re: SuperScouter For FRC -- A Multiplatform, Extensible Scouting System
New data types probably won't come until after the season so as to avoid bugs in version incompatibilities during the initial season. Also because I'm back in school and this semester is looking to be pretty (read: really) difficult in comparison to last semester. |
#32
Thanks for all the hard work you've put in. The customization and QR functionality make this great.
It took me a while to figure out the system but now it will be a lot easier to present to students and see what they think. Paper scouting has always been close to worthless due to time required to sort through everything. |
#33
Thanks for all your hard work and all the information. I would love to test however I'm unclear on to how to "Start HTTP Server" I've downloaded the server and got a couple of schemas created but the "Start HTTP Server" button remains inactive (grayed out). How does that button become active? I am running the server from a laptop that has Windows 7 as the OS. Any guidance would be greatly appreciated, or please point me to documentation/white papers for reading, if available. Thank you!
#35
You need to enter a "Regional" name. Then exit that field.
#36
Some documentation is now available at http://github.com/jkoritzinsky/SuperScouter4FRC/wiki. I'd put this in the first post, but CD won't let me edit it any more.
#37
Thank you for making this system. I love how easy it is to customize to my team's personal needs - I feel like a lot of apps aren't very flexible and I'm very picky with what I want on my scouting sheets. My team is using this for competitions this year!
#38
That is the whole reason I made this app. I wanted it to be customizable because that makes both me and teams happy. I'm happy because now I get to work on new features each year instead of rebuilding from effectively scratch, and teams are happy because they get to collect the data that they want!
#39
Hi, I was wondering if there are any plans to make it so you can pull all sent data from the server from a phone with the app. I am hosting a server over the internet and I just realized that the only option I see to get an export of all data entered is through the server, which is an issue if you are not hosting locally. If the feature is there please guide me to it, if not I would love to see it added, without it it is more or less useless to me, because QR codes have no advantage over paper, and you can't host your own wireless network at a competition.
Thanks, Mat Aztechs 157 |
#40
I'll add the feature to the backlog though. |
#41
Unfortunately, this app does not support Bluetooth at this time.
#43
As Adam said, BT isn't supported right now. BT APIs are a pain to deal with, especially on iOS (BT will probably be Android only when it does come).
#44
I am having trouble with the server. I'm running on Mac so I got it set up in a VM.
![]() I got the server to run and I *think* I have it successfully ported out. However when I try navigating to it I see HTML but it is essentially blank. ![]() I have a couple schema files in the Roaming folder and I'm assuming they should be listed here, right? Why might they not be? Also tried on the Android app, no schemas there. Any pointers? If you wanna release the code I could take a look ![]() |
#45
Are there any schema's available for download or any templates to follow for the schema creation? Please send me a direct message if possible
