14-02-2016, 23:27
Technical Director
AKA: Gus Michel II
 FRC #3946 (Tiger Robotics)
Re: "Quotes" that were said during build season
Originally Posted by Andrew01377
ME:"Collar, Panel, Collar, Arm, Collar, Collar, Sprocket, Collar, Collar, Sprocket, Collar, Collar, Arm, Collar, Panel, Collar."
Ten collars on one shaft, passing through two panels, a sprocket, and an arm?  Someone needs to learn about these wonderful things called spacers.
And maybe bearings.
