Go to Post I hope that all of our new members are as helpful as the one above. We will be in for an amazing season if that is the case. - Greg Needel [more]
Unread 15-02-2016, 00:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: DIY Robot + CIMs?
If you do not expect to exceed 40A for more than a very short period, this looks like a good solution. If you're going to get into a pushing contest, or other application where you need more than a quarter horsepower mechanical output per motor for any length of time, switch to FRC-legal motor controllers.
Unread 15-02-2016, 00:47
REVving up for a new season
FRC #2848 (All-sparks)
Take a look at the SPARK motor controller. http://revrobotics.com/spark
It is $5 cheaper than the one you linked to and is rated for 60amps, with a bunch of other features. It was designed to be a low cost solution for FRC applications, so I am sure it would work for your application.
Greg
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
